Toshiba equium A210 series laptop key board stops working.
My Toshiba equium A210 series laptop key board stops working after about 15min everytime, The key board is frozen and I can noy type but the mouse still moves but you can not type anything. If I turn it off it will work for another 15min before doing the same thing again.Thanks for any help with this matter.
  • sweetlizzyb8 Feb 15, 2009
    Thanks for trying to help. The key board is still not working but thanks again for trying.
  • 1,602 Answers
GO INTO CONTROL PANAL GO TO FOLDED PROBLEM AND REPORTING AND OPEN IT
LOOK FOR ANY MARKING THAT SHOULDNT BE THERE, GREEN MARKINGS IS GOOD BUT ANYTHING ELSE TROUBLE AND DOUBLE CLICK ON THE CHECK MARK AND FOLLOW INSTRUCTIONS
ROD
Posted on Feb 12, 2009
I have internet service through the cable service on my laptop and want to connect it to the tablet without losing it for the laptop
cable internet ?? if so then you have a cable modem at your account location , now there are a few different types of cable modems , and you may need your cable provider to help in answering what kind you have , but based on what you stated u want to be able to do , your going to need a device called a router , some cable modems have these built in and some need them added out board to them , but anyway you need a router to be able to do this , after your sure you have a router , then resubmit your question on how to add a device to a router (or your cable provider may do this 4 you ask them!) and myself or one of the others that know how to do this here will then reply with how , we will need the exact model of router you got to be able to do this
Jan 12, 2017 | Internet Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
I've a acer laptop model no 4820T. In this touchpad option not working but left and right button was working.... wats the problem n wat to do? tel me soon............."
Try the following: Using your FN key and the F7 Key together it might work again. You could have toggled the touchpad off. If that does not work you have issues with either the touchpad or the operating system. Best of Luck.
Sep 14, 2013 | Computers & Internet
P850 049 laptop
Take it back to the place of purchase and get a replacement as it is under warranty.
Do not try to fix it yourself as you may void your warranty.
May 15, 2013 | Computers & Internet
How do I hide my toshiba bar on the left of my screen. it contains photo/video, settings, effect, face recognition
Point your mouse cursor on it, drag ( hold left click) move it to the top of the screen.
or you can try click setting >> auto hide checkbox
akee.4shared.com
Aug 15, 2011 | Toshiba Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
173 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
