Question about Frigidaire Dishwashers
My dishwaher isnt getting any water to it
Its a portable one free standing i guess its called
Check you water source, check for crimped hoses, check water source valve, these are all outside of your dishwasher, internally it may be the solenoid which allows water into the unit.
did it quit all of a sudden/ then i suspect a internal part failure..
RB
Posted on Feb 13, 2009
My portable air comfort free standing air conditioner is leaking water.
Hello Daren,
Welcome to the world of modern conveniences!!
Just guessing here...BECAUSE no Make or MODEL
came through with your question...
but
Just as a COLD DRINK... ACCUMULATES water
(Because chilling warm moist air causes frosting)...
All air conditioners should have a water tray...
I have every confidence tat the unit is NOT leaking...
It is NEEDING to have the drain-pan emptied.
Unless you have a large staff of "domestics"...
That TASK would fall to the owner/operator.
I'M just saying...
Aug 15, 2016 | Heating & Cooling
After cycle standing water remains in the dishwaher
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Bosch Evolution 300 SHE42L1 Built-in...
I have a ariston dishwaher which is boiling water but not filling machine
I called an engineer who dismantled the pump and found a rawl plug in it. Now working fine again.
Apr 14, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
I have a hotpoint dishwaher and every time i put it on a wash it dont do anything, i can hear it trying to start but it dont, and after a few mins it puts itselth in a eco wash, but still dont wash.
Please check the following.
water supply tap turned on?
water pressure supply sufficient, run your tap is it running normally or trickling?
Is the inlet hose kinked, check behind the unit?
Is the door closed properly?
Please dont forget to rate!
What model and how old is your unit?
Feb 27, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Lights flashing on dishwasher and not working!
put some towels dowm and tip the d/w over to one side about 45 degrees if water pours out of the base it means that the d/w is in "flood mode" and you have a leak into the base that will need resolving.
Feb 15, 2008 | Indesit 24 in. D61 Free-standing...
HELP
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Feb 01, 2008 | Hotpoint 24 in. FDW60 Free-standing...
How do I use a portable dishwasher?
no. fix the leak. then, yes, leave it running then yes, go to sleep.
Jun 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
56 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
