3Com OfficeConnect Wireless Router Logo
Posted on Feb 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"Password is incorrect" message when login to Wizard of Router
I attached my Router according to the instrucations.
I'm able to browse to http://192.168.1.1 , but when I type "admin" as the System password i get the message "Password is incorrect".
I tried reseting the Router and also restarting my computer but it doesn't help.
Any ideas?
Anonymous
Level 2:
  • Expert 154 Answers
  • Posted on Mar 10, 2009
Anonymous
Expert
Level 2:
Answers
154
Questions
0
Helped
89988
Points
474
Firstly, make sure that you type the word admin without any spaces before or after, and make sure it's all lower case. If that doesn't work, normally another password has been set. when you reset the router, hold in the reset 'button' with a paper clip or something else small for a FULL 30 seconds, keep the paper clip in place, power the router off for 30 seconds, then power the router on again, still holding the paperclip in place for another 30 seconds. That's 1 minute 30 seconds total (3hours in cat time) but that should force the router into a factory reset. Then go to 192.168.1.1 etc and all should be well" - hope this helps. Dave
Anonymous
Level 2:
  • Expert 49 Answers
  • Posted on Feb 12, 2009
Anonymous
Expert
Level 2:
Answers
49
Questions
0
Helped
84507
Points
319
Admin is id
leave password blank
After doing firmware upgrade on netcomm NB16DG modem router after factory reset password and user name changes. have tried several time to reset and same happens cannot login to basic setup have to go
are you using the default login?
Navigate to http://192.168.20.1 in a web browser using "admin" as both the username and password to login to the router.
I need help putting a password on my wireless connection through my router. How do I do this?
1. Connect your internet to a computer
2. Go to internet browser -> type in http://192.168.1.1 in the address bar
3. You should see the router login page. Type in default user name and password
username : admin
password: 1234
4. Follow a setup wizard to put your device name and wifi password.
I have attached the manual link below:
ftp://ftp2.zyxel.com/NBG-416N/quick_start_guide/NBG-416N_1.pdf
hope this help.
Cannot login into my netgear dg834gb v2 for remote management
Here is a site for your new firmware version:
http://kb.netgear.com/app/answers/detail/a_id/262/~/dg834(v1-%26-v2),-dg834g-(v1-%26-v2)-firmware-version-2.10.22
Here is a site for your product:
http://kb.netgear.com/app/products/model/a_id/2324
Maybe you have to reset it to factory settings.
There is a button next to the power inlet prees it with a pen.
Here is how you acces the router again:
  • IP address: 192.168.0.1 type this in your browser
  • Username: admin
  • Password: password (Sky-branded units have a default password of sky)
  • Function set to Router + Modem
To access the Setup Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Hope this was helpfull.
I am trying to log in to my wireless router
if you browse to 192.168.0.1 or 192.168.1.1 you should get the login prompt.
if you dont remember your password you can do a factory reset by holding down the reset button for 5 secs when you power it on.
login should be admin password should be blank or password.
1helpful
2answers
Cannot connect to NETGEAR_NET
https://www.google.com/search?q=NETGEAR_NET&oq=NETGEAR_NET&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
1helpful
I'm trying to set up my netgear WGT624v3 router with AT&T DSL. I used to have broadband and used the netgear router. Switched to AT&T DSL. Internet is much faster when I go from the modem to the...
Please follow steps to configure your router with AT&T
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
(still doesnot work then click on basicsetting, it will say does your internet connection require login,you need to click on NO then very bottom there would be router mac address you need to select USE COMPUTER MAC ADDRESS then click on apply
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolve issue
Thanks for using Fixya
NEED SMART WIZARD INSTALLATION CD
you can CD from reshaller or vendor there is another way to configure router manualy following is the way to configure router
16. Click Apply.
Regards
prakash
1helpful
Hello, I'm trying to install a firmware upgrade for a D-Link DIR-615 RevA Wireless Router. I'm just not sure how to do it
First you need to login to your router by going to it's IP address.
  1. Open "Internet Explorer" and type "192.168.1.1" in the address bar. If that does not bring up anything try "192.168.0.1"
  2. When the login box appears, enter your login information. If you never set it up try (Login: admin , Password: admin) - if that doesn't work try (Login: admin , Password: password)
  3. Goto the "Tools" tab on the top
  4. Goto the "Firmware" button on the right
  5. Click "Browse" and select the firmware file
I need 2 set up router wihtout the disc
1. Connect the Router to the Computer using LAN Wire.
2. Login to the Router by using this address.
www.192.168.1.1
Note: Default Login Name and Password will be admin and password.
Now, configure your router according to your ISP settings like entering Username or Password.
Lost my setup wizard cd for a X-Micro XWL-11GRIX router
First, Go START | RUN... and type CMD.
When black windows apears, type ipconfig and write down the gateway. This is the address you have to use on your browser. The router will most probaly ask a login and password. Try admin for login and password. It change form manuf. to manuf. Search your Manual for Default Password.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
