Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF340 wont drain
Washes OK but wont drain, the on/off and reduce creases lights flash
I have the HOTPOINT WF540 with the same problem ....So remove the front panel at the front of the machine and you will see the filter plug unscrew anti clockwise, you may find it difficult to unscrew as the filter may be blocked solid with coins ans long objects but once you have started it off wiggle it back and forth with some force till the objects dislodge you may be scared of breacking it but the worst you can do is snap of the plunger which is attached to the filter plug, behind the filter plug its self which will do no real harm and you can put it back in unattached to the filter plug with no worries when your done
you can also drain of the water out of the drum drum from this point but you will need a very slim try to fit under the front of the washer below the filter plug DO NOT totaly remove the plug if the is washing machine is full of water, just release the plug till water slowly trickles out and drain it a bit at a time or you will flood your floor
Posted on Jun 01, 2009
    Sergeant:
  • 197 Answers
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Posted on May 31, 2009
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint washing machine wf340 will not complete a wash cycle it just stop then the lights start flashing next to the mini load button + reduced crease button and the on off button pls help
You have a bad printed circuit board (PC board). You will have to replace. I would rate this job a 4 on a hardness scale from 1 to 10. You will need your model number located on the back of the console toward the top. Go to this site and enter your model number. You can order it with a credit card 24/7 http://www.partselect.com/
Please rate this solution if helpful.
Aug 20, 2009 | Washing Machines
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
We have a hotpoint wd420 washing machine and it wont finnish a wash cycle. wont drain the water either, we do get an error code though in that the door locked light flashes as well as the reduce creases...
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Jul 28, 2008 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
868 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
