Question about Olevia LT32HVM 32 in. LCD Television
I have disconnected my direct TV. Now I attempted to do an AUTO SCAN on my TV using the ANTENNA/AIR option and I only find 2-3 channels. Will bunny ears help me here?? Or is this a common problem with this make and model?
I have spent a considerable amount of time on this, I also have attempted to set the settings back to factory settings and starting all over, BUT NO BITES!
  • Anonymous Feb 20, 2009
    I have the same problema
  • kn4tts Feb 28, 2009
    I have the same problem. It will not search for channels. I only get one channel.
5 Suggested Answers
  • 1226 Answers
SOURCE: No Cable Detected?
Is the TV still warranty? If there is warranty then avail it first so that no risk at your side.
If ever there is no warranty at all then you can open your TV back and verify the loss connection connecting your cable. This symptom also cause by TV tuner error and need to be checked personally by a qualified electronic technician.
ps, please do not rate me if the solution won't resolve, however; it is invaluable solution rate me acceptable.
Posted on Jul 22, 2008
  • 91 Answers
SOURCE: I want to watch TV
You would need to purchase a digital transmitter box for the new digital signals if the tv does not have a digital tuner. You can pick one up at any local retail store, that has an electronic section.
Posted on Oct 22, 2010
SOURCE: olevia 432-s12 tv
I had the same problem with mine I a change the main board you can buy it at ... Good Luck
Posted on Aug 25, 2011
SD Tech
  • 14553 Answers
SOURCE: olevia lct tv can't do a channel auto scan
first check the batteries in the remote to make sure they are not low and then have the remote tested most repair shops do it free.
Posted on Mar 15, 2012
I want to hook up my old 1992 Sylvania TV to HD Antenna, but I cannot figure out how to scan or auto-program the channels. Model SRC1351 101
Hello... Somewhere in the same menu as the Air/Cable setting should be an option to scan for channels. It might be called Auto-Program, or something similar. The bad news is that: "On June 12, 2009, the Federal Communications Commission (FCC) mandated that all U.S. based television signals must be transmitted digitally." Since your TV was manufactured in 1992, it isn't capable of detecting or displaying digital channels. If you're really fond of the TV, you will need some sort of conversion box. If you can afford to, I'd recommend buying a new TV, and get the extended warranty. I hope this helps!
Nov 26, 2017 | Sylvania Televison & Video
After AIR setting and AUTO SCAN, I cannot even receive local channels 4-5 miles away. What is the problem? See below for details.
There may be a problem with the antenna connection. Channels are not being sensed during the scanning process
Dec 12, 2016 | Olevia Televison & Video
I'm trying to hook up a 19" Sansui tv. I'm not on cable, but tried hooking it up to an antenna without any luck. What do I need to do to get the TV to work???
Make sure the TV can receive digital over the air signals (it should have an ATSC tuner), that is it doesn't need a digital converter box. In the menu settings make sure the TV is set to antenna, not cable. You should be able to use the auto-scan (auto-program, etc.) from the menu to find and program the local channels.
Feb 02, 2016 | Sansui Televison & Video
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Model VR-4625 wont pick up any channels with auto scan
Look to see correctly hooked and that in the menu the set is now not set to catv or cable but to air/antenna. If no antenna connected to set or if just indoor antenna you may not pickup on auto search--try to direct enter a known channel with the remote--if you get one you can in the set menu manually add to the memory the set has.
Nov 06, 2012 | Westinghouse LTV-19w6 Television
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
Feb 23, 2011 | Sony KDL40EX600 TV
I have the box installed and on. Now what do I do to get the local stations on my TV
What box - satellite/cable/digital-to-analog converter? This tv has a digital (ATSC) tuner built in. So if you are looking for OTA channels, use or to find out what direction to point your antenna and what antenna you need. Then connect the antenna's coax cable to your TV. Antennaweb is very conservative and assumes an outdoor antenna. will list several more channels and the different antennas that are needed for various distances between your location and the station transmitters.
If you are sharing one antenna between several tvs or tv and other devices, you may need an amplifier in addition to the splitter. (Unfortunately, these can get damaged by surges as well. I've lost certain channels after a lightning strike turned the amp into a filter for one part of the RF signal spectrum.)
Once you have the antenna connected and pointing in the direction of the desired station, you will need to scan for channels. If this is the first time the tv is set up, you will be prompted for menu language, the input type and then asked if you want the TV to auto-scan for channels. Otherwise, hit Menu, use the left and right arrows to get to the Channels menu option and press the + button in the center of the arrow keys. Next use the up and down arrows to set the incoming signal (if needed) - the item is labeled Cable and is a Yes/No (again press + to select item and to enter the change). Continue down to the Auto-program and let that run. You can add/remove channels from the resulting listing with the Channel Skip/Add option just below Auto-program.
I hope this helps.
Jun 21, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
TV displays "no signal" with every input type we try. The only thing that works is the DVD. I even tryed it on a cable cord that was working from another TV
hello are you using a digital antenna, cable or satelite reception? you need to run your "set up" and scan for channels either automatically scan or manual scan, recomend a auto scan for all channels both digital and anolog, these tv will scan and save or store the channels but you need to run a channel scan first,
(even if your using a cable box or sat box)
back when we had the older anolog sets you could just plug it in and watch but with these new digital circuts need to scan and store the channels in before you can watch the broadcasts,, try that let me know what happens. hope this helps
Jun 05, 2010 | Olevia 227-S11 27 in. LCD TV
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
94 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
