Question about Jura Capresso C1300 Coffee Maker, Espresso Machine
Capresso c1300 I am trying to set up it and it does not boil the water i don't know how where to press to boil the water please help me
  • 13 Answers
I believe you have to go through the steps of running a hot water cycle which is on page 9 of the owners manual, 7.1 listed under "FIRST TIME PREPARATION" A. through F. If you don't have the manual, send me your e-mail and I can send it to you.
Posted on Apr 16, 2009
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Capresso c1300
Just a guess here but if you are not using soft water you may have a hard water scale coating on the sensor. The sensor is preventing the heating element from powering up because it thinks there is no water. Try filling the machine with vinegar for several hours (no more than overnight) This will dissolve hard water deposits and hopefully clear the sensor. (the sensor should be a simple continuity contact. If you can look inside and see a metal button and it is fouled clean it off.)
Aug 31, 2014 | Jura Capresso Coffee Makers & Espresso...
Water wont feed for either cleaning or coffee making
In every coffee maker I have ever seen the water moves through the system as it is boiled in the pre-heat chamber. If it is not heating no water will move. Many of those appliances have an internal fuse that is not user replaceable. Those particular fuses (if there is one) can be purchase on eBay but please understand it takes some special skills to replace them. It is definitely not for the untrained in proper safety procedures when working on electrical devices. It could be a switch that is defective but I would bet on the internal fuse.
Feb 28, 2011 | Jura Capresso C1300 Coffee Maker, Espresso...
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
Capresso C-1300 not working
You can re-attach this brown flap youself if machine is not still under warranty (that would void the warranty) or if the tabs or flap is not broken. I have had this machine apart and have taken off the brown flap which have tabs on the top and sides that fits on the front(facing you) of the press (looks like a big white cog inside a brown case( I have photos). The thing is, taking the case off. Screws with special tops that requires specialized tools for removel of case. My husband had to use pliers very carefully to get these out and he said he will put regular same size back in. If you want the manual or photos, let me know yor e-mail.
Feb 03, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Open Questions:
See all Jura Capresso C1300 Coffee Maker, Espresso Machine Questions
Jura Capresso C1300 Coffee Maker, Espresso Machine Logo
178 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
