Question about Dell E153FPT 15" Flat Panel LCD Monitor
Unable to Calibrate: Dell E153FPT
I started having issues with this monitor (Touch Screen) a few days ago basically I can not calibrate it.  when I do the calibration, it shows a message after the last touch that says TOUCH out of range.  Error Calibrating I downgraded the driver to previous version and still the same issue upgrade the driver again and no solution
I did a linear calibration and at each sigle touch, it would show an errors. and when finished still the mouse doesn't show where you put your finger.
Any ideas/?
  • 1,602 Answers
CHECK THE DRIVERS OF THE MONITOR, TRY TO UPDATE THE DRIVES
RESETING THE REFRESH RATE LOWER THAN IT IS NOW
IS THE RESET BUTTON THAT WILL SET THE MONITOR BACK THE THE MANUFACTURE ORIGNAL SETTING,
THAT MITE AN OPTION ON THE COMPUTER ITSELF, SHORTING OUT THE BOIS ON THE MOTHERBOARD BUT WHEN YOU DO THAT YOU CLEAR EVERYTHING ELSE LIKE HD,KB,MOUSE, CDROD,DVD,FLOPPIES, MONITOR SETTING,
ROD
Posted on Feb 12, 2009
How do I connect my Dell P2314T 23 inch Touchscreen Widescreen LCD Monitor to my Dell Optiplex 760 Core 2 Duo SFF ?
you need 2 connections: one for the viewscreen, and one for the touch screen. Then you need the drivers. It supports VGA so use the vga connection if you dont have display port or hdmi. Then, install a USB cable from the PC to the screen to enable touch (and the monitor's built in USB ports) and install the drivers from the dell website, then calibrate the screen.
25066660-ueezjbfcw43osvuczx3w0fyt-5-0.jpgHere is the driver http://www.dell.com/support/home/us/en/04/product-support/product/dell-p2314t/drivers
Sep 05, 2014 | Computers & Internet
Touch screen did work 4 a few days,but its not working now.the rest of phone works
Touch screen problem
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jul 18, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
The calibration on my Samsung Jet mobile is wrong, how do I reset it to make the touch screen work properly
To re Calibrate
Go to setting>phone setting>calibrate
The calibrate screen pops up follow the screen and with the finger or stylus click on the cross image.It will ask for 2-5 times until it is able to detect your response time.Then save the changes.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Samsung Jet S8000 Cell Phone
Dell touch screen uses Touchware to calibrate. The Touchware calibrate button is grayed out? Not sure why?
get the latest touchware driver from 3M from this link http://solutions.3m.com/wps/portal/3M/en_US/TouchSystems/TouchScreen/CustomerSupport/TouchScreenDrivers/
Jun 08, 2010 | Dell E153FPT 15" Flat Panel LCD Monitor
Calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
Jun 13, 2009 | Handmark Software MobileLists (950142) for...
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Sep 10, 2008 | Nokia 6300 Cellular Phone
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Jumpy monitor
I have had the same problem with my dell touchscreen. This problem seems to happen with the newer driver software. I reinstalled the older 5.64 driver and actively touch the screen at start-up when I enter the windows password and it seems to work fine.
May 31, 2008 | Dell E153FPT 15" Flat Panel LCD Monitor
Dell E153FPT 15" Flat Panel LCD Monitor Logo
702 people viewed this question
Alun Cox
