Question about Adapters.com PLANET USB WLAN ADPATER|WL-U356 RTL (WLU356)
Limited or no connectivity
Yes Wireess G Router!
I was signaled "limited or no connectivity" -When I went to check the connection status - details window shows the following:
Property/value
Physical address/00-14-A5-A3-C9-B1
IP Address/169.254.12.39
Subnet mask/255.255.0.0
Default gateway/nothing
DNS server/nothing
WINS server/nothing
When I close that window and select repair
the repair option failed saying to contact network administrator? Guidence Please
  • Mikhail Noltevich
    Mikhail Noltevich May 11, 2010
    The adapter is most likely functioning okay, but it's not getting an IP address, either because it can't connect to the access point or the access point isn't giving out IP addresses. When DHCP times out, Windows will give you an "auto-configured" IP address that starts with 169.254 and is completely useless. What kind of access point is it? Are you using any kind of wireless security?
    Novelist:
  • 126 Answers
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Posted on Feb 14, 2009
I can't connect the wireless network even it shows that the wireless connection status shows as follows: connection status: connected network duration: going on signal strength: excellent However, the...
Your router's wireless encryption setting (WEP) has been changed.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 02, 2011 | Computers & Internet
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
My internet will not connect. Says the strength is strong, but internet is still unable to connect. We are using the netbook by sylvania. We have the lynxis router and the internet is constantly...
Please check in the Network connection whether the Connection status shows Limited/Local only.
If in case the it shows Limited Only, then follow the steps:
1) Unistall Network Driver and restart then Reinstall the Network Driver.
2) Installed Updated Driver from the Manufacture Site. restart.
3) This should resolve the issue. If the connection status show Connected/ Internet. Then Configure the Wireless connection, by accessing the Router. Check the Router configuration and computer's configuration,.
Nov 25, 2010 | Sylvania G-Netbook
Netgear wireless router stopped running on laptop. how to start it up again?
1. You will need to provide some more information about your unit.
a. the model number
b. the operating system you are using
c. are you connected to the router via a Ethernet cable on another computer?
d. Have you check with your ISP as to the status of the your connection.
e. Have you check the status of the router ( in the wireless settings) to see if the PC unit is getting a signal.
f. What is the wireless signal strength of the PC unit / Is it showing in the status bar of the Windows screen you are using.
g. Have you try to repair the connection via the PC you are connecting with wirelessly with. This can be done in the wireless connection icon in the task bar in Windows
I hope this helps. Please provide more information as to your issue.
Jun 17, 2010 | NetGear WNR2000 Wireless Router
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
How do i set up my NetGear DG834G router
Hi this is an ADSL compatible router and will work with DSL or ADSL connection Follow the steps below to configure the router:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually http://192.168.0.1).
5. Login to the router (User Name = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'Router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest
FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest
rating, then please comment to this post and I will try to help you further.
Jul 02, 2009 | NetGear DG834G Router
All light on box are yellowish not green and signal strength is excellent yet not connecting to laptop
If lights on the router are yellowsh then that indicates issue with the router. Please reset the router by pressing the reset hole on the router for 30 seconds and then powercycle it.
now reconfigure the router using the steps below:
Hope this helps
Jun 12, 2009 | NetGear DG834G Router
Lost ability to connect to home network after phone/DSL failure
Recreate your wlan network.
WLAN signal refers only to radio signal between Router and PC no link with your capability to pass-through: wrong password, access list or firewall can block your access with the strongest radio signal.
Check (or recreate ) your credential on your PC.
Check if you can log as admin into your Router.
Dec 30, 2008 | NetGear RangeMax WPN824 Wireless Router...
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Zoom X6 internet light constantly red
the internet light, is usually a blinking green, showing that it's seeing the internet signal. The only reason it's red, is cause there's no net signal..double check the phone line going into the back of your router, and change it if you need to.
check your computers warranty here 4 FREE
Mar 16, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Adapters.com PLANET USB WLAN ADPATER|WL-U356 RTL (WLU356) Logo
204 people viewed this question
Top Adapters.com Computers & Internet Experts
JP Services
JP Services
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
