Question about Nintendo Wii Console
Wii mote non responsive to movement
1 mote works fine no probs,2nd mote all buttons work fine however when moved in play ie tennis the on screan player is not responding,tried the usual re connecting,battries,re callabreting etc,etc even tried tapping against palm of hand still nothing HELP!!!!
any ideas?????????
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,that explains step by step to fix the problem without any technicalknowledge. I hope this guide will solve your problem. It also givesinformation on fixing many Wii Related Problems, so its a kind of WiiProblems Reference Fix Guide.
Posted on Feb 21, 2009
My mote isnt respindind to the scencer!
Posted on Feb 14, 2009
  • USA USA Feb 14, 2009
    HELLO!
Wii fit board has a delayed response
check where your motion bar is located and notice your motions in respect to it. If you are too close your motions will be rash, and thus out of sync.... Try backing up your wii fit board and your stance when playing games. This also gives a delayed response... Make sure you are 6-10 feet away from the motion sensor bar...
May 09, 2012 | Nintendo Wii Fit for Wii
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
Wii big beach sports mulitplayer problem
ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2
Apr 03, 2009 | Nintendo Wii Remote Controller
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
Feb 09, 2009 | Nintendo Wii Console
Twilight Princess isn't recognizing the + or - on the Wii Mote
You need your disc cleaned - take it to a local Play N Trade store and they should be able to get it back to work correctly
Jan 19, 2009 | Nintendo The Legend of Zelda: The Twilight...
How to reprogram on my wii-mote??
Do you know where the SD Card slot is? If not, it's at the front just below the disc drive. Open the SD card slot entrance on the front, and take the back off the wii-mote. Turn the wii on, and at the health warning, hold the sync button on the wii-mote, and the one near the SD slot for 5 secconds. That should do it.
Oct 12, 2008 | Nintendo Wii Console
My wii is not working for certain sports games. Bowling is fine but tennis, boxing & golf aren't. Its like the sensor isn't picking up properly and doesn't recognise when i swing...
Have you tried the game settings?There is an option in the wii menu to adjust the wii mote to the sensor bar.Also make sure both are clean.Be sure the sensor bar is centered with the tv,and make sure you have fresh batteries.Hope this helps!
Feb 17, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
77 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
