Question about Motorola Mobility L6 Cellular Phone
How do i delete a contact on my memory?
How do i delete a cntact on my memory
  • 48 Answers
1.go to ur contact list.
2.Select the contact u want to delete.
3.choose "view".
4.select "edit"
5.select "delete Contact".
6.SOLVED
Posted on Feb 13, 2009
New and can,t set it up for contacts I put in the wrong number and can,t delete it, i am trying to set up my cntacts
Ok well I can help, First if your using android then you need to create an gmail account which will save all your accounts with your contacts using your iPhone or Galaxy or specifically android. I can help you create you a gmail for your contacts , feel free ^_< I'm here to assist you.
Feb 13, 2016 | Alcatel OneTouch Pop C9
How do you delete contacts from phone memory?
Can't you open the contact and press delete at the bottom? Or hold the contact until it gives you a menu then press delete.
Maybe you can go into your settings and memory and have a look in there.
Not sure what phone you have so that's my only suggestions.
If you go into your memory settings just be careful what you press incase it deletes all of your content.
I have an iphone .. I open the contact .. Press edit in the top right and scroll down to the bottom and press delete.
On my old samsung (touch screen) I held the contact then selected delete from the options.
Apr 04, 2015 | Samsung GT-S7500 Galaxy Ace Plus -...
How do I delete contacts from sim card
copy the contacts on the sim card to a sd card in the phone. If you don't have one, get one and put it in the phone. Set up the memory in the phone to both sim and memory card. Copy the contacts onto the memory card. Remove the memory card and then go about deleting the contact list in the phone. Put the memory card back in the phone and set the memory in the phone touse the memory card only...not the sim. You're done.
Feb 24, 2015 | Cell Phones
My Lg GR 500 phone automatically switch Off ? why is that?
weak or bad battery, software problem, battery conector not cntacting well to it contact. Flash the phone with computer.
Aug 11, 2011 | LG Xenon GR500 Cell Phone
Lg kg500 cntacts problem. help please
try to go on your settings, then go to your phonebook, make your lg kg500 phonebook memory through phone. if you have done this, try to reset if to factory, in this case, it will be a fresh phone, but before you do this, make sure to remove your sim and memory card, also, make sure that all the securities are unlocked.
good luck..
Mar 06, 2010 | Cell Phones
Deletion of Contacts from i mate jama 101 without sim
Are the contacts in phone memory or in sim memory?? If in phone memory, There's no problem. Switch on the phone and manully delete all contacts. There's no need of the sim to be inserted. If the contacts are in sim memory then insert the sim. Switch the phone on, and scroll contacts. Chek and find the no.s which have the sim image, it will surely be a sim contact. Then delete it. If you are fearing that your contacts ( if in sim memory ) will be deleted and it is important then first switch on the phone with sim. Note down all sim contacts, after that delete. Then if you give your sister another phone which she likes, switch on the phone and then install all sim contacts which you earlier noted down.
Aug 16, 2009 | i-mate Jama 101 Smartphone
How to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Jun 30, 2008 | Nokia 6630 Cellular Phone
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
Motorola Mobility L6 Cellular Phone Logo
164 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
