Question about HP PSC 2175 All-In-One InkJet Printer
I broke the ribbon
The small black ribbon that goes in front of the cartridges came out of its hole on the left side of the printer. is there hope for my printer?
  • kim_naber Feb 12, 2009
    smooth, it's like it just came off a tab or something
  • rayingrid Mar 01, 2009
    I also have a broken ribbon, it really seems to have come off a tab on each end, the slick ribbon isn't really broken, but can i reattach these ends and fix this problem and how?Thanks Ingrid
  • 1,602 Answers
DOES THE LEAD HAVE A SMOOTH END OR A RUFF END OR A BROKEN AND FRADDED WIRE LIKE A BAD HAIR DAY.
ROD
Posted on Feb 12, 2009
How to install correctronic ribbon
Open top cover, small correction tape orange or yellow lift off is kind of tricky, left side goes on small spool holder feeding off the top and going around front of print wheel. by the way relaase the printwheel so it pivots back toward you, eaiser to see, correct tape goes in front of wheel and pivots very similar to left side. Correction tape has good side and bad side good side a matte finish should face away from you, this is the correction. Regular riboon just lifts up reom the front and snaps back in place. two little plastic tabs on back of ribbon case fits in two little holes in carrier. Hop this helps real hard to describe.just works...
Sep 29, 2013 | Brother Gx-8250 Correctronic Electronic...
Tip
Brother HL 5170DN Printer Toner error
Trick Brother HL 5170DN printer into think there is toner left. Rather than run out for a new toner cartridge use a small (.5 x .5 in.) piece of black electrical tape to cover the sensor hole on the non-gear side of the cartridge. By covering the hole the printer is fooled into thinking the hopper is full of toner.
on Feb 01, 2010 | Brother HL 5170DN Laser Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
I get a message that says "Remove Cartridge and check cartridge on right". I changed the cartridge, same problem. I then cleaned the connection point on the printer with a cotton swab, same message
If there is a spring loose on the right side where that cartridge goes, it may have poked a hole in the ribbon cable when that happens you have to replace the carriage assembly. Sometimes this machine lies and you really need to change the cartridge on the left. Take out the left. cart. and see if the error changes.
Aug 11, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The black ink cartridge has failed
It happens when that spring comes loose from the right side. When you get that hole, traces or wires in the ribbon cable are broken and you have to replace the entire carriage. Around $89.00
Aug 10, 2009 | HP Deskjet 6940 InkJet Printer
Hp laserJet Q2613A cartridge has a silver metallic ribbon on left
yes pull it out its the seal of magnetic rollers u can use the toner properly only after u remove the ribbon by pulling it out completely.
Dec 22, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
HP 7310xi: "Remove and Check Printer Cartridge on the right"
Sounds like the carriage is broken on the black side. Pull the cartridge out and take a look at the silver metal piece. Is it loose from the side and if so did it punch a hole in the circuitry that cartridge comes in contact with. If I were a betting man this is probably your problem. You have to replace the whole carriage. This is a pretty common problem with the carriages that use the #96 and #97 cartridges.
Inkworks
May 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Refill colored ink, what holes, lexmark x5470
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Jan 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
The printer say there is no ribon but i put a new one and still it's not working
try to install again but this time make sure you follow the manual especially on step 5,6 and 7 I list down again the step from the manual 5: Load the new roll of print ribbon on the cartridge. ? Put the full spool of ribbon on the supply spindle of the ribbon cartridge. Push until the spool clicks onto the spindle. ? Put the empty take-up spool on the spindle with the solid black gear. Push until the spool clicks onto the spindle. 6: Replace the loaded ribbon cartridge in the printer. ? Make sure both spindles rest in the black supports on the left side of the printer. ? Make sure the ribbon cartridge handle rests in the supports on the right side of the printer. ? Make sure to install the full, new spool toward the card tray of the printer. 7 Close the printer cover. Press down firmly to latch it.
Aug 30, 2007 | Datacard SP35 Printer
HP PSC 2175 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
