Question about Bissell 3522 PowerForce Bagged Upright Vacuum
My vacumn wont pick up from the bottom but the hose works fine, I have an empty bag and the green light is on.
  • ecase Feb 22, 2009
    Same problem on my model- Rob, how do you get to the belt to see if it's broken? Or what exactly is a glide plate?
    Thanks,
    Emily
  • 134 Answers
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Thanks
Rob
Posted on Feb 12, 2009
2 Suggested Answers
galati2k
  • 281 Answers
SOURCE: My vacumn wont pick up from the bottom but the hose works fine.
your belt is probably broke before you replace the belt clean the motor shaft old rubber may still be on there.make sure your brush roller turns freely
Posted on Apr 05, 2009
My vacumn won't pick or suction up and bag is not full. I cleaned out the hose checked and belt running I have no other answer please help. It's an upright lux guardian
The output filter on that unit is HEPA and traps all particles. You need to clean or replace that filter because the airflow cannot leave through it and it wont develop suction.
Feb 06, 2015 | Vacuums
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
My vacumn wont pick anything up and it wont self propel. I checked the belt - it is fine.
There are numerous things to check.
  1. Check for hose clog
  2. Brush belt has many hairs and doesn't move
  3. Brush belt broken/loose
  4. Vaccum bag is full
  5. Height adjustment according to floor.
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
sounds like you have the plastic bodied canister. the controll valve inside is bad. I usually just disconnect those to avoid future problems. you may want to take the vacuum to a repair shop though becuase they are a pain to get apart and get back in one piece.
Jul 15, 2009 | Electrolux Vacuums
My vacumn wont pick up from the bottom but the hose works fine. I emptied the bag and the green light is on.
Thanks
Rob
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Willnt pick up good...
I had this problem once too. When the hose is inserted into the vacuum, the floor unit (where the spinning brushes are) becomes the head of the vacuum. In other words, the suction goes through the floor part and then up through the hose and into the vacuum. If the suction is good when the hose is out, the the problem is blockage at the bottom piece. Take the cover off of the rollers (it is one screw then it pops right off) and see if there is a bunch of lint/hair/gunk blocking the suction hole. You could also take the hose part out of the vacuum and look down the empty shaft with a flashlight and see if you see anything there. Hope this helps!
Apr 04, 2007 | Fantom Vacums FM760 Twister 500DX Bagless...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
110 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
