Broadband connection failed frequently
Sir,
I am using bsnl broadband connection.my connection.my connection failed at every 5 minutes . what is the problem
  • Anonymous Apr 06, 2009
    my connection also shutdown frequently
    almost within 4-5mins
    i have to reconnect
    due to this all my downloads are going haywire
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there
    What connection are you using? LAN or wireless?
  • 1,602 Answers
CHECK THE SECURITY FOLDER AND THE FIREWALL INSIDE THE CONTROL PANAL
CHECK THE NETWORKING AND SHARING OF INFORMATION WITH THE COMPUTER NETWORK. YOU WANT GREEN MARKS NO OTHER TYPE OF MARKS LIKE,ORANGE,RED,YELLOW,GRAY,BLUE
AND SO ON.
CANDYMANGANDY
Posted on Feb 12, 2009
I am unable to open many sites while using bsnl broadband..
BSNL have aways been known for its network problems
there are many websites actully lakhs of domains who are not authorised for use in bsnl domain.
SO. its better you try switching to some other broadband or 3g connections other than bsnl
Dec 27, 2010 | Computers & Internet
Sir The belkin wireless router is not responding in BSNL PPOE broadband connection what is the way to get connected through the ISP of BSNL. murali
IF u are using the BSNL broadband connection, you might be having a modem provided by the BSNL, 7230 model is only a router, it doesnt have modem option so all u have to do is
1. Go to belkin page 192.168.2.1(if u changed the ip address in router, then type the default gateway of the router)
2. Click on connection type
3. Setup as a dynamic connection since the PPPoE is already set on the modem
4. Follow the on-screen instructions
5. Check the internet status, if its still showing as not connected then powercycle the router for 15 sec and then reconnect the cable
Hope it will work
Sep 29, 2010 | Belkin (F5D7230-4) Router (587009)
Dna-a211-1-adsl 2-for-bsnl-broadband CD Download
I HAVE A DNA-A211-I BSNL MODEM. I RESET IT CONTINUE 4-5 TIME AND AFTER RESET IN MODEM DSL AND WLAN IS NOT WORKING AND MODEM IS NOT CONNECTED TO MY PC. I USE WINDOWS 7 HOME PREMIUM. RESET BUTTON IS NOT WORKING. SO PLS SOLVE MY PROBLEM.
Oct 21, 2009 | D-Link DSL-300T Modem
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
Adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
Apr 11, 2009 | Computers & Internet
Sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
BEETEL 220BX ROUTER
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - abialexin@yahoo.com
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
347 people viewed this question
David Payne
David Payne
