Question about Garden
My briggs&stratton ohv 17 hp electric starter will not turn over
My electric starter will not rotate engine until I rotate the engine past the compression stroke manually. What do I do to fix it?
  • benj31744 Feb 14, 2009
    I have replaced the battery and I have jumped from my car battery-- and it makes no difference-- it won't start unless i rotate engine by hand past the compression stroke. Then it usually will spin it and it starts. The mower is 2 years old and it runs fine-- but I never have adjustewd the valves--since my 12 year old Kohler has had no problems at all.
  • Anonymous Mar 22, 2014
    LT1000 18 hp OHV not turning over to start. too much compression? is there a decompression valve on this motor?
    President:
  • 1,388 Answers
I worked at a tool rental center while attending college and encountered the problem that you are having many times. The problem was caused be a variety of issues however can be determined by checking the following:
Worn starter motor bearings that would be indicated by higher than normal amp draw. Check for hot starter motor or hot cables.
Weak battery. The battery should be removed and tested for free at auto parts store. The battery should be replace every season to extend the life of the starter motor.
Belts or hydraulic pump that is not fully releasing from engine pulley or output shaft. Remove the spark plugs from the engine and tune engine by hand, it should turn rather freely.
Finally, compression release feature of engine is not working properly. Check engine service manual for proper adjustment of valves so that compression release will work. Finally check oil level for over full. Too much oil will raise compression. Good luck with your problem and email for more info.
Posted on Feb 13, 2009
  • John Trevino Feb 15, 2009
    Your car battery surely has enough amperage to smoke starter. Since you did not mention that starter is very hot after attempt start, then mower battery cables or starter solenoid could be faulty not allowing full power to reach starter. If starter is very hot, then it is dragging. If cables solinoid or connectors are hot, suspect weakness. Starter motor has permenent magnets bonded to inside of case. Sometimes the magnets will come loose and rub against the armature (will drag down the armature and get hot) Generally, there will be heat where there is restance. An amp gauge will reveal draw and compare this to manaul.
Had same problem, thought it was the battery, so i replaced it. Then I noticed a flash under the fender when I tried to start it with the new battery. Turned out to be a loose battery ground wire. Tightened it and now it cranks fine.
Posted on Apr 11, 2009
    Scholar:
  • 76 Answers
You may want to check to see if your battery has enough charge to it. If the battery isn't fully charged it won'be enough to make the starter spin fast enough to start the engine
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine won't stsrt as starter won't wind over past compression stroke. starter and battery good
check your valve adjustments, quite common for this to happen when the valves go too far out of adjustment.....it will work better with them adjusted too
Jan 27, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
B&S 17 hp single it only turns over til it hits compression.. good battery,starter turns over another motor ,ground wire,whats up!
The connections on the starter solenoid coil are poor. this is the two smaller wires on the solenoid but all of the wires should be removed and cleaned well at least once a year or more often if conditions warrant.
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starting problem after setting for ten days or more
Take the spark plugs out when this occurs and try to pull it through--does it expel fuel or oil? This should tell you whether you have a flooding fuel problem, or maybe the crankcase is overfull of oil causing it to leak into the combustion chamber through worn valve seals or piston rings. Hope this helps!
May 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
1,152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
