Question about HP DeskJet 5150 InkJet Printer
HP 5150 loses connectivity every couple of days.I get a message that says the printer has lost its connection. All cables are good. I have the identical printer at another location and when it is used with my laptop everything works great. It is the second unit that seem to have this problem. In my print dialoge box I have 2 printers listed: deskjet 5100, and deskjet 5100-1 (this is the problem printer) Using Mac Powerbook G4 with 10.4.8. A reboot solves the problem but what a pain. hghh
    President:
  • 2,692 Answers
I do not know which driver you are using since three different Ones are listed  8,9, and OS-X. I f you are not using OS X  or at least 9, I would consider trying them , if I were you,since you are currently using 10. The driver page states that if you OS in not listed. then they do not recoment this printer,in so many words.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=304431〈=en&
Posted on Feb 12, 2009
Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
Installing hp 5150 printer gets hung up on last phase searching for hardware
generally, this works for me: Make sure the printer is disconnected, uninstall the driver, reboot
download the latest driver from HP.com
Run the install and when prompted, turn on printer, then connect the USB cable to the computer and let it detect.
If the printer still doesn't install normally try this
http://www.fixya.com/support/r3680773-completely_remove_printer_drivers
and this
Apr 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Connecting my hp deskjet 5150
well it will either have a usb cord, or a parrllel port(which is unlikely)
connect the cable download and install the driver from the link
http://www.softwarepatch.com/utilities/hp-5150.html
this shld work
Nov 08, 2009 | HP DeskJet 5150 InkJet Printer
I keep getting message that there is no connection to computer but the cable is plugged in etc
Hi
There are several reasons this is happening. Check the cable on both ends. Make sure there is no sign of damage either in the cable or the computer/printer connector. I see at least one a day where the printer cable is plugged into a damaged USB port. Printer fire wire ports do break off their mother board too. The other possibility is that you're temporarily losing your USB ports on the computer. At Start, goto run and type SFC /scannow. This program will try to reinstall all the original protected files. Have you original operating system disks handy because if SFC finds files missing then it will ask for these disks. Good Luck
Aug 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP Imaging software hangs up intenet connection
Put the printer back in the box it came in.....
Jun 10, 2009 | Linksys Wireless-N WRT150N Router
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Lost disc HP deskjet 5151
Go to the HP website and use thier software down load package it is easy. I lost my HP deskjet 5150 disc that was hw i was able to reinstall it to new system. I hpoe this will help you. I sure do know it will
Jun 11, 2008 | HP DeskJet 5150 InkJet Printer
WON'T PRINT TO DESKTOP
did u check your printer with another system or laptop
i guess that will help u...
thanks
Dec 27, 2007 | HP DeskJet 5150 InkJet Printer
Installing printer without lost cd
Hi ! -- go to http:/ /h10025.www1hp.com/ewfrf/wc/sofw...
---fixed the problem through the prompts !
Printer now online and working !
Thank-You !
nigel
Sep 26, 2007 | HP DeskJet 5150 InkJet Printer
Changing ink cartridge
Did you take the little plastic strip off of the ink cartridges that protects the connectors?
Jun 26, 2007 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
