Question about Toshiba 57HDX82 57" Rear Projection HDTV
Used windex to clean tv screen and now it has blotches on it?
Where can I get a replacement screen for my tv?
  • Anonymous May 09, 2009
    I used windex it has blotches on my HDTV LCD. How can I fix it. Is there anythign I can do?
    Genius:
  • 2,920 Answers
You can order one through a tv repairshop or from the dealer. either way it will be costly to replace
Posted on Feb 12, 2009
Liquid got between frame and screen how do i get it out
need to dis assembly the frame of the tv and take the 3 screens out and cleaned may sure you put this back in the same way you took it o each side is different do not use any cleaner like windex
Dec 18, 2010 | Mitsubishi WD-60735 Projection Television
How do you clean the screen on a panasonic flat screen tv
When I first got mine, I used Windex and a microfiber cloth to clean it.
Now, I use Phillips Screen Cleaning Gel. It does a better job and doesn't leave streaks like the Windex did at times.
Whatever you decide to use, the best thing to do is spray the solution on the microfiber cloth instead of directly on the screen.
Using a microfiber cloth will ensure you're not inadvertently scratching your screen.
Aug 23, 2009 | Panasonic TH-50PX75U Plasma HDTV
My nephew spray windex on my dlp tv and not is in between both screens n it black but you can move the water still with your fingers
Well I'll say this. There has been no damage done yet. The problem is that the windex has wicked up in between the Lenticular screen and the Fresnel lens screen. If you attempt to seperate both screens yourself then I can guarentee you will damage both screens.
Not cheap to replace both screens. The screens CAN be cleaned with a screen cleaner from Screen Clean but the real problem is finding a Highly qualified technician who has done this many times before. The Fresnel lens screen is EXTREMELY soft and has tiny ridges that damage very very easily and you will see permenant black streaks in the picture. Never use Windex,Amonia or 409 and the like cleaners on the screens. When you use a screen cleaner, spray the cleaner on a MICRO cloth (Very Soft) then carefully clean the scree. Like I said, the screens can be cleaned safely only by a Highly skilled technician. The black spots from the windex will not eventually go away. Contact the tv manufacture as they can direct to a authorized service center they trust.
Jul 08, 2009 | Televison & Video
Clean screen on 42 in flat screen tv
I just bought a 42" lg hdtv very nice but had a big spoto in the middle of the screen. I used windex wipes to clean the screen and it is good as new again!! Hope this helps!!
Dec 02, 2008 | LG 42LC2D 42 in. LCD HDTV
Black blotch on bottom of screen
if you can take the screen out , then use some dish soap,rag and water to clean the black blotch
if that don't work you may need to use something a little stronger , but not enough to hurt the screen
please rate a fixya and I'll be happy to assist you in the cleaning process and care of the screen
Nov 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
I need to know how to clean the LG flatron L1953T screen without damaging it in any way? should we just used windex or not? it has been wiped with a damp cloth and now has water marks.
Please do not use Windex. Use Anti-Static Monitor Wipes for LCD screens. Using Windex or other cleaning solutions like it will cause streaks on your screen. Damp cloths have the same effect as Windex.
May 04, 2008 | Computers & Internet
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Feb 21, 2008 | Televison & Video
Dark blotches behind the screen
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Dec 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
Toshiba 57HDX82 57" Rear Projection HDTV Logo
556 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
