Question about Sony Televison & Video
Samsung / Sony LCD panel cross reference
I know that Samsung made Sony's lcd panels. Does anyone have a cross reference chart?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    It is classified information and would be available on factory level.
5 Suggested Answers
  • 395 Answers
SOURCE: replace protective platic panel in an lcd tv
unfortunatly the protective screen is not available as a seperate part, it is the whole LCD panel that needs to be replaced. if the TV is the LC-42d62U then the part number is R1LK420D3LF21 and can be found at www.vancebaldwin.com for $2362.80.
Posted on May 11, 2008
SOURCE: REPLACEMENT LCD PANEL
Have a look here I have the same problem and have been looking for 3 days...I hope this helps as I have tried the service manual and the part number is...1-805-870-21...with no luck...http://www.invertercentral.com/qrySpecSheet.asp?page=srlp&name=LTA320W2-L02&number=LTA320W2-L02&title=Toshiba&Country=Australia
Posted on Jun 16, 2008
mistersony
  • 320 Answers
SOURCE: lcd screen
You can get the panel replaced. The problem is that the cost of replacing the screen usually exceeds the cost of repairing the unit.
Posted on Oct 19, 2008
  • 133 Answers
SOURCE: lcd base screws
they are medal screws, about 1.5 inches long, and they are fine thread
Posted on Jan 11, 2009
jerryg50
  • 1667 Answers
SOURCE: SONY KDL-52xbr4 - lcd panel shot after 17 months
This can be the panel itself, and or the matrix decoder/driver boards. The cost of this type of repair can approach the cost of a new set. From your description, I am thinking it is the panel itself that has failed.
Parts for your set are from Sony only because there is no third party manufacturing for these types of parts and assemblies.
Usually, when these types of sets become defective they are usually not worth servicing. During warranty the manufactures generally give a new set to the client, or they give a re-built set which has been built up using parts and modules from other sets that came back for service and had different types of problems.
If you know a tech is is good at servicing these types of set, maybe he can find a number of scrapper set of the same model to take parts from. You just have to hope the ones he finds have the same types of fault.
Jerry G.
Posted on Aug 06, 2009
Samsung 57" Vertical lines across the screen. Is this repairable, and if so, is it costly?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. The latest model Samsung LCD TVs, the T'Con board is the integrated part of the LCD panel; and so it is not replaceable. Instead, the LCD panel should be replaced.
This is a trade secret; you know? Samsung is now following this trick, first introduced in this industry by Sony.
Jul 02, 2016 | Samsung Televison & Video
How to change samsung tv t con board
Ken, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
LCD TV Repair
Troubleshooting Distorted Video Con of LCD Panel TV Repair Vizio Sony...
Mar 22, 2016 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
Is it worth to replace the LCD panel ?\ The Replacement LCD panel code is BN95-00604A How to do the LCD panel repleacment
Considering the price of a TV I'd say not.
Did a google search and found this site using BN95-00604A: http://www.encompassparts.com/item/9186449/SAMSUNG/BN95-00604A/PRODUCT_LCD-AMLCD where they list the part at 565.00 including a 102 core charge which I presume would be returned to you once the core is received. It is unknown if this source is the only source, that this source would actually sell the part to anyone other than authorized service providers, it also doesn't address shipping costs or taxes and damages that may occur in transit. Also from this site, I learned that this part is used in a Samsung UN40ES6100FXZA 40-Inch Led 6100 Series Smart Tv
Here it is on Amazon for 829 with free shipping: http://www.amazon.com/Samsung-UN40ES6100-40-Inch-1080p-Black/dp/B0076M04QU
Samsung UN40ES6100 40 Inch 1080p 120 CMR Slim LED HDTV Black 2012 Model
Apr 28, 2014 | Samsung UN40ES6100 40 Inch 1080p Smart TV...
Can anyone tell me if a LTA460HT-L03 LCD panel is compatable with my Samsung LN-T4661F? Thanks in advance, Mike
While I can't tell you that for certain I can tell you that you can simply open the cover of your Samsung and look up the LCD panel number used on it.
Once you know the panel used in your model you can start looking for compatible panels.
Another good way to look for that is to compare the TCON (LCD controller) boards used by the two panels.
Hope this helps. If it does please rate it - we need feedback ratings as you need our advice...and yes, I realize that I didn't give you simple and direct answer...but the simple truth is very few people will know the answer...and much more will know how to find it.
We are from the second kind :-)
Oct 18, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Problem for choosing lcd tv
When you buy a samsung, you buy a LED TV with a panel manufactured
by the company "S - LCD" which belongs to 50/50 % sony and samsung.
The S - LCD company is fully driven under samsung engineering.
Today, sony seems to buy their panels from "sharp corp" and trying to
seperate from samsung due to the cold war (high competition ) between
them
Just go for the samsung UN32C6500 32" 1080p LED HDTV.
Theres no better picture quality you can buy for 32".
Good luck....
Jun 14, 2010 | LG 42LC2D 42 in. LCD HDTV
My lcd flat screen plastma tv screen got broken.i want to know is is repearable.
KDL-46S2000 Panel cost approx $1500 +$3000 core charge, Part # 1-802-100-31.
Parts reference: Andrews electronics, 800 289 0300.
May 08, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a samsung LN26A330j1D lcd tv ,the screen comes on black then fades to all white from the center of the bottom.does anyone know what part would be out causing this ?
There are a number of causes. First The T-Con bd has gone bad. Second the Main bd is bad and third the LCD Panel is bad. Have a trained Samsung tech troubleshoot the problem
Jul 11, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Need a Replacement LCD Panel Module for a Sony Bravia KDL-32S2000
I don't have a listing for the model that this is posted under, but the replacement panel for similar model KDL-32s2010 is $2232.55
I would expect the cost of your replacement to be similarly priced. If you post your specific model, I will attempt to get the exact price and part number.
Dan
Feb 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I need replacement screen for Samsung Digimax D103
You may try to contact 1-800-SAMSUNG and have your camera sent for service.
Jan 04, 2009 | Samsung Digimax S800 Digital Camera
Nov 21, 2007 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Televison & Video Logo
530 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
