Question about Montgomery Ward Refrigerators
I have a Montgomery Ward refrigerator Mod. #HMG21644. Refrigerator compartmet is not cooling. Fan and fan stat are working. Freezer is working fine. I don't have a manual so I can't troubleshoot it, what's my next move?
5 Suggested Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Master_Tech
  • 770 Answers
SOURCE: Admiral Refrigerator Model HMG671581 bought from Montgomery Ward 9 years ago.
Thanks for the chat
I really belive after 20 years of service on home appliances this is the problem with your unit. If you call a repair company to come out and it is not the issue (dirty Condenser ) I will refund your money on this chat.. Sound fair?? my email is gary@appliancedoctors.ky please email me and let me know...Have a great day
Posted on Jan 29, 2008
Richie_asg1
  • 1036 Answers
SOURCE: montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Posted on Jun 17, 2008
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
rayname
  • 70 Answers
SOURCE: Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Posted on Jan 03, 2009
Is there a manual for a Montgomery Ward compact mini freezer with this model license # 8113.07 and serial # 54020? SL?
This information is usually readily available direct from the MANUFACTURER and/or ON-LINE. If you don't have access to a computer just see your local store or give the manufacture a quick call ...
  1. Montgomery Ward Refrigerator Support ' ManualsOnline.com
    kitchen.manualsonline.com > ... > Refrigerator Support
    Montgomery ward refrigerator product support information from ManualsOnline.com. Find montgomery ward refrigerator user manuals, instructions, and free ...
Sep 20, 2014 | Refrigerators
Montgomery ward refrigerator, running but not blowing air in freezer or refrigerator sections. compressor is running and evaporator is cold . I believe the fan motor is out. How do I get to it to change...
First of all I'll need to know about how old it is and second where is the fan located ie. on the rear wall or on the bottom of the freezer compartment?
Nov 01, 2011 | Refrigerators
Need to know how to access and replace freezer fan motor on 70's model montgomery ward frostless 21
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 16, 2011 | Montgomery Ward Refrigerators
Where is the refrigerator fan on my side by side? How do I get to it to see if something is caught in it? My freezer is cold, but my fridge is BARELY cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Montgomery Ward Refrigerators
Freezer is working fine-but refrig is not cooling. Refrigerator is about 15 years old, side-by-side.
heatman101
Jul 25, 2011 | Montgomery Ward Refrigerators
Samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Apr 28, 2010 | Refrigerators
Freezer working fridge is warm fan not blowing
ur solving ur own problem the fan either needs to be thawed ,lubed,repaired or replaced the fan uses the air from the freezer to cool the fridge side but bench test the fan before replacing if fan good than check the thermostat in fridge for proper working order
Nov 26, 2009 | Montgomery Ward Refrigerators
Freezer compartment runs continuously
icemaker running continuously but producing no ice
May 03, 2009 | Maytag MTF2156GEB Top Freezer Refrigerator
Refrigerators Logo
111 people viewed this question
Top Montgomery Ward Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Montgomery Ward Refrigerator Expert? Answer questions, earn points and help others
