Question about Dell 1720dn Laser Printer
Dell 1720dn Printer
Print out are crooked or slanted and some times there is a banging noise while printing
  • pgiegucz Feb 12, 2009
    I already replaced the fuser.
    Sergeant:
    Champion:
  • 237 Answers
Sounds like the fuser needs to be replaced or the pick up rollers need to be replaced
Posted on Feb 12, 2009
  • John Cole
    John Cole Feb 12, 2009
    Have you replaced the pick up rollers yet and also try a new toner cartridge sometimes those will hold up the paper. Does the print look like its straight or does that look crooked also?
  • kenn green Aug 10, 2011
    The problem u are having, is called the clutch (making the loud bangs an clicks. Eventually it will lead to paper jams in the near or distant future. The labor on the repair is about 2 hours
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
May 06, 2014 | Dell 1720dn Laser Printer
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
My Dell 1720dn constantly has paper jams. A
I am having the same problem, did this get resolved?
Dec 02, 2009 | Dell 1720dn Laser Printer
Dell 1720 printer prints crooked i.e. left margin is not parallel to edge of paper
most likely you have a bad pick-up roller. it is inside the printer directly above the paper tray. this is one reason the paper would pull in an angle.
Nov 12, 2009 | Dell 1720dn Laser Printer
Why does my dell 1720dn print crooked?
The paper feed rollers are dirty and are pulling the paper in at an angle.
Could be from high % cotton paper or sticky label printing.
Clean the "pickup" rollers with eyeglass cleaner (not Windex).
Nov 06, 2009 | Dell 1720dn Laser Printer
Dell 1720dn all indicator lights flash after printer is powered on for several minutes. Once this happens, I can no longer print. If I power cycle the printer, it will function normally for a time.
this printer is actually a modified LExmark E238...if printer under warranty, demand they replaceit.
if all lights flash..usually means a hardware printer problem Main board.
May 06, 2009 | Dell 1720dn Laser Printer
Dell laserjet 1720dn
Reseat the paper in the paper tray, and replace the pickup rollers for both trays, note the pickup rollers are in the trays and under each tray.
Feb 12, 2009 | HP LaserJet 4250n Printer
Dell Laser Printer 1720dn Will only print test pages. When attempting to print a document, I click on 'Print', and the command is sent to the printer que, but the printer doesn't print. I've tried deleting...
Check that the correct printer is set as default. Also use File Print so that the selected printer is shown rather than using the Print button. If the test pages are being printed from the computer then the communication is working.
Dec 31, 2008 | Dell 1720dn Laser Printer
New secondary tray not recognized on vista.
Dell Laser Print 1720 dn Properties window. Click on the last tab called install options. Click the ask printer button. This should update the print driver with the add on drawer.
Oct 30, 2008 | Dell 1720dn Laser Printer
Dell 1720dn Laser Printer Logo
475 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
