Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter Fan heater thermostat is stuck
I have a Hunter C42214 heater which was working fine until today. I did lower the temp yesterday, which may have affected the programming?
I have programmed for 22 degrees, but the unit keeps showing 20 and this number is constantly flashing, and the heater is not coming on.
Thx for your help!
  • 52 Answers
SOURCE: Hunter 44260 thermostat
Here is a link to directions on setting up the programming modes on your t-stat. Follow them and you should be fine. Good Luck
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Posted on Jan 29, 2008
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
Well, I consulted with Randell (my 12 year old grandson) - he assisted me in finding the solution in converting cooling to heating on the touch pad. Jameson (the 4 year old grandson) looked on, wanted to help Pa-Pa - but, we could only listen to his demands to help.
I still need an instruction manual - can you advise me how to obtain a replacement (or print one from the internet)?
Your response will be greatly appreciated.
Regards,
J. Alan Overton, Sr.
Posted on Nov 19, 2008
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44002.pdf
Posted on Jan 09, 2009
VtToolMan
  • 704 Answers
SOURCE: thermostat takes too long to cool down 1 degree
Thermostats don't cool or heat. They are just the control device that tells the furnance or AC to operate and register the present temperature and tell the furnance or A/C to shut off, once the desired temperature has been reached.
Most programmable thermostats will take at least 1-2 weeks to "learn" how long to run the furnance or A/C in order to reach the desired temperatures you've programmed into it, for the time you want it be that temperature. Variables such as extremely hot days and higher humidity will also affect your cooling system.
Give it a little time to self-learn and it should adjust itself after a week or two of operation. You might want to take some time to review and familiarize yourself with the owners manual to see what Hunter advises for setting up and using the thermostat.
You may need to have your A/C checked to see if you're running low on freon, or need to have the coils cleaned, need to change the air filter, etc.
Hope this helps and best regards!
Posted on Aug 01, 2009
  • 3640 Answers
SOURCE: I have 2 of the same Hunter Douglass ceiling fans
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Posted on Jun 01, 2011
2002 dodge neon running VERY HOT ... what to do next?
Have you verified that system has been "burped" of air? That the fans kick on? Check radiator hoses for kinks. You can try running without the thermostat to see if that helps and can identify if the thermostat could be a problem. You may need to check your coolant mixture too.
Sounds like you have reduced flow or restriction in cooling (heat exchanger) as it runs fine at cooler temp but can't keep up when it gets warm.
New parts don't always equal working fine parts.
May 23, 2017 | 2002 Dodge Neon
2002 Ford Taurus SE. Heater motor and fan work fine on all speed settings but the air coming from the vents is moderately warm at best and not hot when temp selection is to hot. When I move the temp...
Check the heater valve is fully open when in the hot position , this valve or tap often get stuck half open. if all is ok there flush the heater radiator as they can silt up.
Apr 19, 2017 | 2002 Ford Taurus
It doesn't get warm or hot at all. and when or if it does get warm it takes FOREVER.
I assume you are talking about your engine temperature gauge reading? I had a problem with my 1996 Caravan thermostat (V6 3L). It can get stuck wide open and never allow the engine to operate at the specified temperature. On my vehicle, the thermostat has a metal tab that would prop the valve wide open if it failed. I think the thought of the designer was better to be stuck open than full closed I guess. Anyway, my vehicle temperature would never reach normal range with it stuck open. For my vehicle it is 195 F. This time of year, it would take a very long time before your engine would reach normal running temperature. The interior heater would also take a long time since the engine is also cooler. If your vehicle is newer it can also cause the engine check light to come on because this would affect the emission control systems and keep your engine in a cold engine mode loop...
Not knowing a lot of details of your situation, I would check:
The gauge is working correctly and plugged into the temp sender near the thermostat.
You have the correct fluid level (Please be careful checking this)
Your heater core and engine radiator not clogged with sediment
Flush out your radiator and heater core
Replace your engine thermostat with the specified temperature range your vehicle requires (parts store tech can help you obtain the correct one)
Good Luck.
Jan 01, 2011 | Dodge Stratus Cars & Trucks
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
How do you set the thermostat??
hi
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
riz.
Feb 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
121 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
