Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven - Failed baked goods, takes too long on other things
I have a Kenmore electric range, about 5 yrs. old. Over the past several months it has been acting weird. Some things ok, some not. It has taken twice as long to cook a custard and I have had flat cakes. Casseroles seemed to take too long, too, but it always depends on the starting temp. of the casserole... It would seem that the oven might be too cool but using a separate oven thermometer, it shows that the temp is actually 50' too hot! Does that make sense? What can I do?
  • Anonymous Mar 03, 2009
    I have the exact same problem, and possibly the exact same stove
    Problem Solver:
  • 14 Answers
Most ovens have what is called tempture sensor,its job is to read the tempture within your oven if this sensor is faulty then it sends the wrong signal to your display,you talk about a thermometer showing a different temp please do not put this thermometer in your oven some of these contain mercury and could explode in your oven.I would advise you to call a electrication and get him to test your tempture sensor.sorry i cant help you any better.adrian
Posted on Feb 14, 2009
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F7 keep popping up on my wall oven
The fault code is for the ERC The ERC electronic Range Control has failed. If shutting off the breaker for at least 5 minutes does not clear the code you will need to replace the erc. This is the main control located behind the clock assembly. This is easy to replace but usually not to inexpensive. Enter your complete model # at www.appliancehelponline.com and you can pull up diagrams and illustrations of your specific model. All parts come with installation instructions.
May 12, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Bottom of kenmore oven pitted
Baked on debris causes this. The spots are from food sitting there without being cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 08, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Trying to self clean my kenmore electric oven get error msg e1 f5
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Oct 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Glass top and oven 7 months old still has the new oven smell
possible that the insulation that surrounds your oven cavity has yet to fully cure, i would run a clean mode, this will get the unit to max temp fro 3 hours, fully curing any insulaton for sure
Dec 02, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Aman biult in oven
F2 is Oven sensor is out of range .. oven sensor is sending a reading that the control can not understand... replace oven sensor and you may have to replace the control too as it may not be reading correctly... good luck and let me know if it helps
Jan 02, 2008 | Amana AOCS3040 Electric Single Oven
Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
134 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
