finger tight cable wire to my 52 " samsung and the cable jack broke right off at the base. ( finger tight) cheap metal or what? have hard time h.h.gregg to swing my way on this what do you think? physical damage my fault. but cheap setup i say. im a electrician never broke that ever before.
This is clearly not your fault! and sounds like a defect in the manufacturing process happend to this part!! if you used your fingers THIS PART SHOULD HAVE NEVER BROKE!!
hope this helps
tv only recognizes up to channel 13. I've tried to auto program & manual program up from 13 but...
(More)
tv only recognizes up to channel 13. I've tried to auto program & manual program up from 13 but the tv always stops at 13.
I have been trying to work on my nephews Panasonic CT-2??? tv it doesn't have a manual but it does...
(More)
I have been trying to work on my nephews Panasonic CT-2??? tv it doesn't have a manual but it does have a remote when it isn't hooked to the cable it gets channel 3 and 4 but when I connect it to the cable box I can't get any channels but if I bypass the cable box I can get the regular cable channels but in order to get the expanded cable I have to have the tv on channel 3 but it will not allow me to add the channel. I've done many scans auto and manual but 3 and 4 will not come in. Do you have any secrets to get channel 3 on so I can use box to get the expanded cable? And there are not reset buttons on the back of the tv or box that will let me set it to channel 3. Thanks
