Question about Sony KP-53V80 53" Rear Projection Television
Sony Proj Tv model #kp-53v80 : sound fading in and out
I have a Sony Color Rear Projection Tv model KP-53V80. Recently the sound has started fading in and out. There is no consistency to the lass of sound. Sometimes it's just a few seconds and sometimes several minutes. Any suggestions?
  • 1 more comment
  • jamesemassey Apr 01, 2009
    I have the same problem, and my surround is turned off. I don't seem to have an option for expanded.
  • sknight515 Apr 08, 2009
    I have the same problem and it's drive me nuts. NO rhyme or reason as to why it does it. Sometimes it's hours before it starts and then other times it starts doing it right away.
  • dhurt May 11, 2010
    Make sure the "expanded audio" or "surround" feature is off. See if it still does it.
ladywinn
  • 5138 Answers
SOURCE: Sony KP-53V80 53 in. Is it HD Compatible
Yes it sure can.
Posted on Feb 01, 2008
rockitman187
  • 2559 Answers
SOURCE: I have a Sony Projection
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
Posted on Jan 18, 2009
ladywinn
  • 5138 Answers
SOURCE: 3 different images in color sony kp-53v80
Replace Both of your convergence ICs They are big black ICswill have part number on them STK392-110 Order the same # as your STKs have on them Call Mats for Parts 1-800-628-1118 also CK pico Fuses they look like resistors will be green or yellow they are fuses.
Posted on Sep 27, 2009
  • 139 Answers
SOURCE: sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Posted on Dec 27, 2009
AJIN G
  • 6694 Answers
SOURCE: Sony projection tv...Screen blinks on and off to black several times a minute...audio and everything else is fine
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.....
Posted on Jan 13, 2017
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
Lines across screen & no sound
KP 53v80 is way too old to be fixing---recycle it as most landfills will not take that as it has toxic Glycol inside of it.
Apr 29, 2012 | Sony KP-53V80 53" Rear Projection...
Sony model KP-53V80 wont show picture or sound
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
Sep 27, 2009 | Sony KP-53V80 53" Rear Projection...
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
Check IC1509, Q1505
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Sounds like one of the tubes is shorting out causing the set to go into a shutdown status so it won't cause any major damage to the set or house.
Sep 06, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Sony tv model #kp-53v80
you have most likely a shorted hori out out NTE2324 and look around hori there is a 1200pf 2k volt cap that goes bad.I have fixed alot of sonys with this problem.
Jan 28, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
