Question about Canon PowerShot A75 Digital Camera
Low battery signal coming on with new batteries
Just put batteries in camera and after using for a few minutes it gives low battery signal and will turn off.The batteries are good.
  • snoddywilko Feb 24, 2009
    i put in new batteries and it immediately says change the batteries. i am using duracell and they are always fine. it is as if the camera is just not reading the batteries atall.
  • Canon Master
  • 4,738 Answers
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Feb 13, 2009
Low battery on screen and shut off
These cameras need good batteries. Make sure you either are using quality Alkaline batteries or NiMH rechargeable.
Oct 30, 2013 | Casio Exilim EX-FH20 Digital Camera
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Photography
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
My canon SX110 IS camera has recently started displaying 'battery is low' and flashing the red low battery sign even a few minutes after putting in brand new batteries. I have tried with several new sets...
I had the same problem with new batteries reporting as "low" and instant shut-off. After I found that it would stay on when plugged into USB, I suspected a firmware bug in the camera (I am a computer engineer). So I thought "how can I fool it?" I then found that it would stay on if you power it up with the rotary dial BETWEEN the video and manual ("M") setting -- in the "illegal" position. The after it's on, every mode works!
--Dan S.
Ithaca, NY
Oct 22, 2010 | Canon PowerShot SX110 IS Digital Camera
Nimh batteries give low batt signal even when
the trouble with rechargable batteries is their voltage is low to start with even when charged. they only give 1.2 volts each instead of 1.5 volts from proper AA bateries. I use Energizer Lithiums in all my camers and they are great and last a long time. You can find cheap suppliers on eBay I use a site called 7dayshop.com in jersey (europe).
Jul 25, 2010 | Olympus FE-25 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Even after putting new batteries it gives message"change the batteries"
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new, may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Oct 07, 2008 | Canon Cameras
Battery low all the time
Try Eneloop batteries from Sanyo. They have the higher voltage needed. AND that voltage doesn't sag under the initial startup load.
Nov 02, 2007 | Cameras
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A75 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
