Question about Microsoft Xbox 360 Console
No connection to my tv
Please Help.
My console powers up using controller or on its own, but cant get it to connect to tv. Even tried hooking it up to my mates tv and leads.
  • karlsmart Feb 13, 2009
    no sound at all
    Sergeant:
    Champion:
  • 378 Answers
It might need to be serviced. Do you hear sound? If yes then its the solder under the Gpu chip. We can do this for you if your interested we are listed on this site.
www.videogamerepairservice.com
Posted on Feb 12, 2009
My nintendo 64 is not showing up on my emerson tv
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip:
If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Aug 06, 2012 | Nintendo 64 Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nov 25, 2011 | Nintendo Super NES Console
How can I hook up my Wii to my mothers TV? It is usually connected to my TV...I cant get the Wii to acknowledge the Wii remote at all.I even tried changing the batteries/remote but nothing. My 10yr old...
To get the Wii Mote Connected to your wii Take off the back cover of the Wii Mote, Hold down the Red button for a few seconds, Then on the Wii Console pull open the little door just under the Disc Drive and press the Red button on there. This will allow the Wii-Mote to "Sync" to a different Wii-Console
Hope This Helps.
Mar 19, 2011 | Nintendo Wii Console
When i turn on my ps3 the green light comes on and nothing else. It wont show up on the tv or anything, not even the controllers with will connect to the ps3 and once it on i cant turn it off with the...
Have you had it hooked up to hdmi? And now your trying to play with a/v cables? What model? some models you can hold the power button down until it comes on and shuts off then hold it down again until it beeps twice release power button and a menu should come up for you to reset settings.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
SEGA MEGADRIVE
dont know how many times ive said this but
GET AN OLDER TV
it saves all that time you use trying to hook it up to a new one..it doesnt even have to be that old just not a plasma or HD tv, its much MUCH easyer and saves lots of time, and mabie even money
Apr 13, 2010 | Sega Megadrive Black Console
No sound, now the conrtoller doesnt connect
You gotta hook the controller back to the system via the usb cord and then press the PS button. Finish the format.
Let me know if you still have problems afterwards.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Cant connect to wireless
try resetting the ps3 by turning the power switch on in the back then try holding the power button for about ten seconds. then turn the ps3 back on and try setting up the connection again. you may have to set your audio and video settings again as well.
May 11, 2009 | Sony PlayStation® 3 (60 GB) Console
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
