Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
NHDE35 Enclosure I have the NHDE35 enclosure and when I connect it to the USB, it shows that a device connected but in MY COMPUTER nothing is shown ad a device. any idea or help be appreciated. P.S I have tried to put my Seagate HD 7200.7 in a master, slave or other options before with no success.
Posted by Decoder1 on Feb 25, 2009 I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
Randy P.S. I am using a Seagate 250 GB HD 7200.7 Ultra ATA
Posted on Feb 25, 2009
My Nexxtech nhde35 ext. hard drive is suddenly not working. Now when I plug it in, the indicator light alternately blinks red/blue. The PC does not see the drive at all. Tried swapping to another hard...
Seems most likely that the drive enclosure has failed, since swapping to a different HD made no difference. If so enclosure will have to be repaired, or replaced.
Jan 03, 2011 | NexxTech Portable Hi-Speed USB 2.0 Kit...
POWER ON BUT WANT DISPLAY NOTHING AT ALL
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 22, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My computer has always recognized my 250 GB Simpletech external drive, but now it won't. The red light shows on the hard drive when I plug it into the USB Port but nothing else happens. I search under My...
* the USB cable
* the power-adapter
Dec 17, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Powers up... orange light on front... Nothing going on... windows detects the hard drive when I plug it in... but doesnt show it in the "My Computer"
* the USB cable
* the power-adapter
Dec 14, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
For some reason my Hitachi external hard drive is not showing up on my computer. I know that once i plug it in it should show up on My Computer but its not. What should I do??
* the USB cable
* the power-adapter
Dec 13, 2010 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
My simpletech, which is the 360GB model. It is plugged in to my laptop, but when I go looking for the drive it is not showing in my drectory. I going throught the process as if my computer is seach for the...
* the USB cable
* the power-adapter
Dec 12, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
The piece that allows a usb cord to connect to the actual external hard drive broke off and i no longer can plug it into my computer. how do i get the piece out or fix it?
* the USB cable
* the power-adapter
Or, buy an "empty" external disk-drive enclosure, for about $30, and "transplant" your disk-drive into this enclosure.
Nov 21, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Not showing in computer
* the USB cable
* the power-adapter
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 12, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Won't show up on Mac desktop or inconsistently
* the USB cable
* the power-adapter
Nov 09, 2010 | Fantom Titanium Hard Drive
I have a iomega eGo HDD and its not showing up on my computer but it shows up under my devices how do I fix that
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
Nov 04, 2010 | Iomega Computers & Internet
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
419 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
