Question about Toshiba Satellite Pro L300 Notebook
Headphone problem I can hear sound through the speakers (as well as the headphones) when I have earphones inserted. HELP!!!
    President:
  • 2,692 Answers
The female earphone jack should disconnect the speakers when the male jack cord plug is inserted.   First try another male plug. If that doesn't work either.  then the female jack is broken or malfunctoning and wil have to be repaired or replaced for it to operate correctly. .
Posted on Feb 12, 2009
  • 1,602 Answers
GO INTO CONTROL PANAL GO TO SOUND OPEN FOLDER GO TO SOUND TAB AND FIND WHAT ITEM YOU ARE HAVINGISSUES WITH HIGHLIGHT IT AND TEST IT TO.
DEVICE MANAGER IN CONTROL PANAL, CHECK THE DEVICE AND IT DRIVER AND ANY NEW UPDATES
When I plug in my headphones into the earphone jack on the HP xw4600 workstaion and play music i can hear the music from the 2.1 speaker
If you are saying when earphone plug is inserted you still have sound from speakers either jack on headphones is wrong(stereo or mono?) or the socket the jack plugs into is defective---when a jack is inserted it moves a leaf in the socket to turn the main speakers off.
May 17, 2012 | HP Computers & Internet
There is no sound on my receiver but if i insert my earfones i can hear the sound
Hi!
The problem can be caused by the earphones connector on your Garmin. Usualy, when you insert the headphones jack, it disconnect the internal speaker, and when you remove the earphone jack the internal speaker will connect again. But sometimes there can be some dust/dirt in the connector on your garmin that prevents the connection.
It can be cleaned very easy by a air flow from a compressor, compressed air cleaning spray can or even from a vacuum cleaner. Do NOT use your own exhaled air, because you will get a lot of moisture into the device that coul damage it.
Please let me know if it helped.
Regards,
Aug 20, 2011 | Garmin n vi 300 GPS Receiver
I'm not getting any sound out of the speakers. I have sound through my headphones but cann't get anything out of any speakers.
If you can hear the sound from the headphone(earphone jack), the fault is between the headphone itself or the speakers. Check the continuity of the speakers(voice coil) using the multimeter to determine if it is faulty or not.
If you've confirmed that the speakers are not the issue here, you may spray an electrical contact cleaner to the earphone jack of your unit while pulling and inserting the headset plug to clean the contact from dirt build-up inside. You may also replace the earphone jack with new one to back the unit in normal operation.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 18, 2011 | Teac AG-V8060 Receiver
I have a Panasonic Sa-HT930 surround sound system. Plugging in headphones does not turn off the speakers, yet I can still hear sound through the headphones. How do I get the speakers to turn off??
The switch of the main speaker does not engage when you plug inn your earphone it's suppose to turn off the main speaker.you need to clean the contact of the switch of the jack.Open the cover of reciever and go to the earphone jack spray it with a contact cleaner then try again.if the same thing happen replace the jack with a new one.
May 28, 2011 | Televison & Video
No sound
Hello
First you check the speaker of your Daewoo Tv. To check the whether the speaker is good or damaged, place your year very close to the speaker side of your TV, and switch the TV by its front panel power switch, not by the remote control. If you can hear a "Thumb" sound from the speaker, as the TV is switched on, the speaker is good and you have to to further. If not speaker has got damaged and have to be replaced.
If your TV is provided with an earphone or headphone socket at its fron panel, insert a earphone or headphone pin into it and listen whether there is sound coming from it or not. If ther comes the sound, it doesnot comes to the speaker, means that the headphone or earphone socket is faulty. Replacing it will solve the problem.
If there is AV OUT from your TV, connect it to an amplifier or so to get the sound. If there is sound and no output from speaker, means the Audio Output IC inside your TV is faulty.
Just locate the audio output Ic, and replace it with same type and number. Audio Output IC can be easly located ans speaker wire goes to that section, and follow the speaker wire. locate it. If you need any more assistance, feel free to contact me through Fixya. OK.
Dec 07, 2010 | Daewoo DTQ-20U9SC TV
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
No sound on speakers but earphones are working in hp G60 243 DX notebook PC laptop may send help at dhingra.ashok@gmail.com
YOu need to replace the speaker for your system since you can hear sound using headphones it means that the sound card is good,
Jul 17, 2010 | HP Computers & Internet
Headphones and sound.
Hey guys!
Since the internal speakers are working, the sound portion of your pc is set up correctly and working. That is also confirmed by the fact that the sound goes away when you insert the earphone jack.
That means that either your headphone jack is defective (I doubt that, since 2 of you seem to have the same problem, but possible), your earphones (or cables) are defective, or there is a compatibility problem with the earphone jack in the pc and the earphone plug on the earphone cable. Just because the plug fits the jack, doesn't mean that it's making the proper connection. I've been stung with that one myself, a time or two. That's about all there is to that circuit.
The only other thing that I might suggest is that you try to plug the earphones in, hold the Fn key while pressing the F8 key a couple of times. That key combination toggles you speakers on and off. Doubt that will buy you anything, but it's worth a try.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 29, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite Pro L300 Notebook Logo
391 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
