Question about HP LaserJet 4250n Printer
When printing the paper comes out wrinkled. How can we prevent?
When we go to print copies from our computer usually the first 1 or 2 pages comes out wrinkled. It doesn't do this every time, but often enough that it is a problem. Is there a way to fix ourselves without calling service?
    Genius:
  • 2,120 Answers
Buy a fuser kit from HP
Posted on Feb 12, 2009
Paper jams after printing 1/3 page. continue s to print on on wrinkled paper until file is totally printed
The rollers need cleaning. Office supply stores carry cleaning paper. It's sticky on both sides. Run it thru without printing on it. That should fix it.
Jan 24, 2014 | Epson Stylus Office Equipment & Supplies
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
When we print something,the paper comes out and is wrinkled and has some ink on it in places where there is no print. The fuser checks out fine.
Description sounds like the fuser rollers are bad.
To check it out run a 1/2 test.
Put paper in the manual feed tray. Print something. As the paper gets 1/2 way into the printer, open the top cover,(you might have to print a few sheets to catch it just right) take out the toner and look down at the paper. If it is wrinkled, you could have a bad toner cartridge. If it looks good...get the fuser replaced.
Jun 15, 2011 | HP LaserJet P3005n Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Paper printing with wrinkles on hp 4100 laser
Pressure roller is worn. But the whole fuser assembly could probably stand to be replaced.
Mar 28, 2009 | HP LaserJet 4100n Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
HP LaserJet 4250n Printer Logo
129 people viewed this question
Ben Johnson
