Question about Panasonic PT-52LCX66 Projection Television
My Panasonic PT-52LCX66 popped and cracked
And wouldn't turn on, lamp indicator flashed orange 3 times, tried turning on again and red lamp indicator flashed red 1 time. Ordered new lamp ( needed tv for super bowl) and still didn't work. Took to repair shop and he said it was the power supply/ ballast board and the part would cost $300 and with labor $350- $375 and he couldn't guarantee it didn't short out anything else, so it could possibly cost more. I spent $268 on the lamp whch I don't think is returnable, The tv is only 26 mo. old. Is it worth repairing? And what is the actual part name of the board he's talking about?
    Novelist:
  • 184 Answers
His prices sound a little steep. Most ballast boards un $100-$200 Labor and service call should be $250-300. If you are bringing the TV to him, it should be less. Check with Panasonic for an authorized servicer in your area for a quote and maybe a little help with the cost of repairs. Sometimes, the manufacturer will agree to cover the part cost or more, so call them!
michtech
Posted on Feb 13, 2009
Tv wont turn on even with new lamp
We recommend you have the TV evaluated by an authorized service center.
Mar 09, 2014 | Panasonic PT-52LCX66 Projection Television
Tip
Panasonic PT-52LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
My Panasonic PT-52LCX66 worked for about a week after changing the lamp. Now it won't turn on. 3 orange power blinks and 4 red temp blinks. Please help! My husband is to hard to babysit without a TV :)
Three orange power blinks indicates a 'Malfunction 5', and that your unit requires servicing. You can try pressing POWER on the unit for over 7 seconds, and then turning the set back on after 5 more seconds. If this doesn't help the set needs servicing.
If you didn't reset the lamp timer after replacing it, you might try that by following these steps.
If you think browsing the troubleshooting section of your operating manual may help, you can access it here.
I hope that helps.
Mar 31, 2010 | Panasonic PT-52LCX66 Projection Television
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
Aug 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX66 Projection Television Logo
391 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
