Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9300PW water leak
Our machine is 2.5 years old and has started leaking water from the front. We took the drawer out and in looking the fron, we can see the water dripping from the bottom center of the washing machine. The leak only occurs when water is being added, not during soak or agitation, and a little leaking occurs during the spin cycle.
Should we pay a repairman to fix this? Or call Whirlpool? We have an extended warranty, but were advised by Warner Stellian, whom we bought the set from, that the warranty only cover major parts such as the motor.
How can we determine if it is the door seal or the tub seal? What is a reasonable repair cost for a door seal or a tub seal?
Could the problem be related to improper balancing or installation? The machine is sitting on a Whirlpool drawer that we purchased with the set and when we use the High Speed spin, the thing moves 8-10 inches from the wall and is very loud during the spin cycle.
Thanks so much!
Amy and John
  • 5,911 Answers
The problem, I suspect, is the door bellow. This is the gray rubber boot on the door and front of the tub. The key is the fact that it only leaks during fill, or when adding water, and only leaks in the front center. The washer fills through a dispenser tube in the door bellow. Water runs through this tube and into the front portion of the tub. If you pull back the rubber folds of the bellow and look, you may have some rips or tears causing the water to drip out. If there are no obvious signs of wear causing the leak, the other two possibilities would be the dispenser tube not inserted through the bellow all the way. That is, the tube may have slipped behind the bellow a bit and may be causing water to drip BEHIND the bellow instead of through the fill port. Another cause would be if one of the clamps that hold the bellow in place has come loose and is not sealing to the front of the tub, or door frame properly. The following link explains how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I provide this link not only to give you advice in the event that your bellow needs replaced, but also to give you steps necessary to access the bellow in order the check or tighten the clamps. NOTE: An alternate method to checking the rear bellow clamp (located on the front of the tub) is to remove the washer top panel and attempt to access the 7mm clamp nut from the top. The method I have described in the link, however, offers the best access. NOTE: The clamp needs to be seated evenly around the entire perimeter of the tub facing and the clamp should be SNUG. DO NOT overtighten. This will cause damage to the clamp and/or tub facing.
If you require a replacement, you can order on line at appliancepartspros.com. Just type in your model number and look under the "Door and Latch Parts" heading for item number 5. Other items of interest are the rear bellow clamp, item 6 and the front bellow clamp, item 14. In most cases the clamps do not require replacement and can be reused. But, just in case you have to replace them, you now have them identified.
You can perform this repair on your own, if you like and save the cost of expensive labor charges. This is not a difficult repair, if you follow the instructions provided. This repair can usually cost $200 or more (cost of the part, plus the labor) if you have a repairman do it.
The problem could possibly have been caused by excessive vibration, but its hard to tell. Washers mounted on a pedestal can often have vibration problems if the washer is not mounted properly to the pedestal. Make sure all mounting bolts are installed that hold the washer to the pedestal. Make sure they are tight. Also, proper leveling can be an issue. DO NOT attempt to level the feet of the washer on a pedestal. Mount the washer and adjust the feet of the pedestal for proper leveling. Make sure the unit rests on a flat surface and is level front-to-back and side-to-side. A good foundation is also required to ensure the washer does not vibrate. If the flooring under these washers flex (even the slightest) they can cause vibration problems even if it is properly leveled. Flooring in an upstairs laundry room or a mobile home is usually the worst. Another item to consider is the pedestal itself. Look at the back of the pedestal. Is it open in the back, or does it have a back panel that encloses it? If the pedestal back is open, this can cause a condition known as "tin-canning", where the sides of the pedestal waffle in and out and begins to bounce when the washer spins. This can be overcome by purchasing a stiffener kit. Look at your pedestal and let me know if this may be the issue with yours. If so, I can provide you with a part number to order.
If you have further question, please let me know. I hope this helps you.
Posted on Feb 12, 2009
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking water
Please be very careful, electricity and water don't mix. With that said try checking the hoses and make sure the hose clamps are secure. I have a Whirlpool washer and have had this problem among several other assorted problems. Glad I took out a service contract it more then paid for itself in the last two years.
good luck,
Marty
Jun 21, 2014 | Whirlpool Washing Machines
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
My whirlpool front load washer leaks water from the detergent and softener drawer
Ours filled up with soap deposits. We simply took the drawer out and cleaned it and all is well. Hope this helps.
Feb 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet frontload washer leak
a quart of water over the course of a cycle is pretty significant, other then trying to remove the fabric softener section looking for a blockage in the dispensor(which is basic and should be real evident ) theres not much more for you the consumer to look for.(or should you have to for that matter its why you bought a NEW appliance). As for the service , you've purchased a Whirlpool product, therefore you can call any whirlpool authorized Company out to service you dont need to wait for Sears!!!!!!!
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from detergent drawer
Remove the control panel. Inside you will find a service tech sheet that will identify the error code.
There may be an obstruction in the water valve inlet flume forcing the water to travel in the wrong direction.
Jan 05, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Leaking from the dispenser
Try to pull out your dispenser drawer gently to clean out thoroughy. If you cant succeed, use a tooth brush, see that the brush does not fall in. Probably you have dried powder blocking the passage, nothing else.
Rate me pl.
Nov 12, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
535 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
