Question about Sharp AR-5316 Advanced Digital Imager Copier
How to get into service mode on sharp ar-m277
Annd which is the code number to do auto toner after repacing the developer
    Problem Solver:
  • 4 Answers
There is no such model number of a Sharp copier.
Posted on Feb 17, 2009
Sharp AR-5516 F2 displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 but not solved please tell me
Hello Sir,
More exactly what is your error? F2-02 or F2-04?
For F2-04 try to change toner cartridge or verify if the chip on the toner cartridge is correct positioned.
For F2-02 you must verify if toner sensor is not dirt, the toner sensor is positioned on back of developer unit, clean very well.
Best Regards,
Dec 09, 2011 | Sharp AR-5516s
Does a Sharp AR-M277 use 1 or 2 bags of developer?
Hi, the Sharp AR-M277 takes 1 bag developer (type AR-271MD).
Jan 05, 2011 | Sharp AR-M277 Digital Copier Copier
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
We have a Sharp AR-M277. The screen says maintenance required.
Hello sir; Which means is you need a PM that including replace drum, drum blade, developer, corona wire etc. very complicate, if you really interest let me know, I'm happy to give you instruction.
Oct 26, 2009 | Sharp AR-M277 Digital Copier Copier
Knocking noise
sounds like the developper
it may start to stiffen up.
remove the developper (toner cartridge and try turning the gears by hand, if it's practically impossible to do) replace.
Aug 12, 2008 | Sharp AR-M277 Black and White Copier
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
170 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
