Question about RCA P56923BL 56" Rear Projection Television
Mitsubishi WS-48311horizontal scroll
The picture loks great but rolls, constantly from l to r
Is there an easy fix or should call a service tech?
i have the back uncovered but see no horizontal hold...lol...it rolls horizontally like the old TVs did when you had to set the Vertical Hold correctly.
shrek
  • Den Schrecengast Feb 13, 2009
    The TV is not a 56"
    It's a 48" modelWS-1080WS-48311
    Thanks
    Novelist:
  • 184 Answers
Its not a problem you can easily fix. Many Mits TVs of the mid-90's had a PIP board in them that had dried up surface mount capacitors on them. The board would have to be either re-built or replaced at a considerable cost.
michtech
Posted on Feb 13, 2009
I own a WS-48413 Mitsubishi 48" projection TV that has been working great for 7 years. Now all of a sudden there is no sound, only a picture. Tried to trouble shoot with the manual, but no luck. Is...
amlupo,
If the picture is good and you use Comcast as your cable supplier I believe that your Comcast converter box is bad. This is a very common problem and an easy one to fix. Call Comcast and tell them the problem and they should replace the box for free.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | Mitsubishi WS-48413 48" Rear Projection...
My picture getting dark red and moving slowly to the left. My manual is missing and I can't remember what to do.
Ok I have found you a user manual. http://www.retrevo.com/support/Mitsubishi-WS-65511-TVs-manual/id/276ci860/t/2/
Below is the service manual. http://www.eserviceinfo.com/index.php?what=search2
I cannot be sure, if that is something that simply needs resetting or some problem. However I suspect that there may be a problem with the Color Wheel or Alignment. Of course it may be a filter. have a look through the service manual and run through the set up again. This may fix the problem. But I wonder if it will be that simple, we can only hope.
Mar 12, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS 55413. Ongoing rolling screen.
First check for the coolant/fluid leakage from the picture tube on to the signal board. Wipe it with paper towel and dry it will the hair dryer. I hope there's no corrosion yet.
Dec 28, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-A55, HD1080 Series TV picture scrolls horizontally
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Mar 05, 2017 | Televison & Video
My picture looks like it has a roll in it i can hit the tv a clears up for about 30 secs
It sounds like you have an intermittent connection or defective component in the vertical oscillator circuit. Not a DYI fix. Get a repair estimate from a qualified service tech before you over spend on a repair.
Aug 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Picture won't hold it keeps flipping over and over
look for dry-joints on the guns and convergence boards
Apr 01, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi ws 55807
Good Day;
It sounds like your TV is experiencing a CONVERGENCE CIRCUIT failure. YES, it is worth repairing, it's a great TV. The cost will be from $450.00 to $650.00; call an Authorized Service Center and have them give you an estimate B4 repair. Good luck, big IRISH. PS: It's Not An Easy repair to do your self.
Sep 08, 2008 | Mitsubishi WS-55807 TV
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
