Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Ice maker is not working
There are no air bubbles in the line, temp is good, but we are not getting any ice. We have good water flow through the water part but no ice.
  • tarufelliang Feb 12, 2009
    yes, Had this frig for about 6 months
    Problem Solver:
  • 7 Answers
Check that the arm is down on the ice maker itself, also read the instruction manual to see if there is a seperate on/off switch for the ice maker
Posted on Feb 12, 2009
  • Dr Plumb Feb 12, 2009
    could be a number of things need more info, is this a new installation?
    so its under warranty? call the 1800number for their techs they may have a solution over the phone.
Amana refrigerator ice maker
You are on the right track since the solenoids control the amount of water reaching the ice maker and the water tap. Sometimes over a period of time the plunger or moving part of the solenoid just gets stuck and a good cleaning will restore it to proper operation.
Mar 16, 2017 | Refrigerators
Water does not flow
first you should take the water feed off, clear all water out of tube going to ice maker.remoe ice maker and check the wiring and all looks good.hook water up,turn water on just enough to see you have waterflow yo ice maker.might need a towel or two in the freezer.replace icemaker,make sure bar on ice maker is down,turn water on full,give it 12hrs to make ice. good water flow-no ice--replace ice maker.
Jun 02, 2012 | Jenn-Air JCD2389G Side by Side...
Change water filter indicator came on so i changed the water filter now the refrigerator won't make any ice, checked the on off button in the ice making unit which is on, what the problem?
This unit has water dispenser and ice maker? If yes, you must get all the air out of your water line, how to do this is keep fill water glasses until you get a good flow of water and no more air, also the water may drip some what so. until all the air is pushed out of the line your ice maker can not make any ice, please let me know what you find. Thanks Rick...
Jul 26, 2011 | Refrigerators
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
The fridge is no longer making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
OR
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 19, 2009 | Freezers
Ice maker stopped making ice
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | LG LFX25960ST Stainless Steel French Door...
GE model GSH25JFTACC ice maker not working
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Icemaker in Admiral side by side refrigerator/freezer stopped working
see if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Whirlpool ice maker
Hi Chubbo,
 When you say you checked the Valve, did you check the Supply valve that feeds water to the fridge, or the Solenouid valve that usually casues this problem.  Unplug your Fridge and roll it away from the wall.  Remove the  rear access panel  and trace the water supply tubing to the solenoid valve. Lots of time the valve is bad.  You  can get a replacement  Solenoid.  at any Appliance part store, or online at www.repairclinic.com
If you did check that. You can get a coupling that will adapt from the water supply directly to the line coming from the solenouid to pressure up and see if you actually have a flow problem between the solenoid valve and ice tray.
Hope this is helpful to you. Good Day
Oct 18, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
102 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
