Question about Sony Car Audio & Video
Help asap okay a jeep cherokee and i got 2 12's jl audio w3 w/ a 1000 watt apline amp but um i got a sony explode cd player and it works and everythin my amp turns on but the subs dont work there not blowin cause i hooked them up in my friends car but idk i have the right wires hooked up and theres only one wire i dont know wat do to with its the blue power antenna wire what that bee the problem? i tried everythin dont know wat to do
Hook blue wire to ur radio to amp remote
Posted on Feb 15, 2009
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
How can i make my jl audio 12w3-d6 into a 4 ohms
it depends if the amp is mono or stereo and if it is bridged. if it is bridged the amp cant handle the speaker the best way is to lower the level on the amp or connect it to only one channel. also you might want to check your ground cable use a thick one and make sure its making good contact with the chassis. this happened to me. luck
Sep 12, 2009 | Jl Audio 12W3 Car Subwoofer
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Green light blinks slowly on my JL Audio 300/4 amp
Check your fuse at the battery. While AGU glass fuses "look" good, when you read the voltage AFTER the fuse, you can only be getting 5 volts or so. I can't tell you how many times I have seen this.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Jl Audio 300/4 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Nov 16, 2008 | Jl Audio E1200 Car Audio Amplifier
Wiring an after market Sony CD Player into a 89 Jeep Cherokee Laredo
there might be a amp in the car , so you need to make sure the blue wire off the sony radio is hook up the the remote wire to the stock amp
Sep 21, 2008 | 1989 Jeep Cherokee
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
No sub when listening to a cd
THE PROBLEM YOU ARE HAVING IS THE REMOTE WIRE ON THE EXPLODE IS BLUE AND WHITE AND THE BLUE WIRE IS FOR THE POWER ANTENNA
Dec 28, 2007 | Car Audio & Video
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Car Audio & Video Logo
113 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
