I have a marantz sr-18U that came with a bad center channel. I took the amp board with a good center channel out of another sr-18U and put it in. It burned up the good center channel on this board too. I thought the problem was in the board, but it must be something else since it burned up the good one too. I have enough parts between the two of them to rebuild the center channel but I think it is just going to keep burning up the center channel. Any idea what the problem could be?
  • 4 more comments
  • ssryan2 Feb 12, 2009
    How would you fix an over voltage supply to the center channel. I haven't checked it yet but just wondering what the cause would be.
    what would cause the center board to receive too much power?
    I want to know how to FIX it. If that turns out to be the problem. I'm not home right now so I can't test it.
  • ssryan2 Feb 14, 2009
    Can anybody tell me if the sr-18a and sr-18u are the same thing? I'm trying to find a service manual, but can only find sr-18ex or sr-18a.
  • ssryan2 Feb 17, 2009
    OK, I have rebuilt practically the entire board 4 times and it keeps burning up the same components. Can anybody tell me what might be causing the over voltage supply to the center channel?
    anybody?
  • 4,234 Answers
I don't have service info on this so we'll need to rely on experience with audio. What parts are burning up? I'll try to walk you down the diagnosis path. This may take a few iterations, but we should be able to resolve this. If the amp section for the center speaker uses discrete transistors, remove the output transistors completely and fire up the receiver (not literally of course...) and measure the voltages on each of the three pads and post them here.
I'll post the next steps based upon the voltage readings.'
Dan
Posted on Feb 17, 2009
    Brigadier General:
  • 5,158 Answers
Check all the capacitors in the power supply section (well all the boards)... if any feel swelled up on the tops or appear to be leaking.... they have failed and need to be replaced.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
May I offer an alternative view? Almost always, the +/- power supply of the center amp would be common to all the other amps. Additionally, it would be very rare if regulators are utilized in the finals/outputs and therefore would be unlikely for the +/- supplies to go high. Alternative possibilities are:
  • shorted center speaker/speaker wires;
  • faulty pre-amp section;
  • faulty sound processing board;
  • shorted/leaky decoupling capacitors (1 ~ 2.2 uF).
A possible test is to check for the absence/presence of DC voltage at the input wire of the center amp. With the unit selected to any unused Audio/Line INPUT, the input wire going to the center amp should read 0 DCV.
Additionally, the difference in the last 2 characters often indicate regional versions. Regional differences include AC power in (120, 220, 240 & 50 or 60 Hz) and tuner/frequency stepping/separation.
Good luck and thank you for using FixYa
Posted on Feb 14, 2009
    Sergeant:
  • 326 Answers
Its not exactly the same but the system and settings are near to same so you can continue with that service manual.that will give you the fair idea of fixing.and also work for you.
thanks.
please do rate the solution.
  • 547 Answers
It could be you should contact
  • us.marantz.com/Products/296.asp if it's not that old thay do have warenty
  • Marantz America, Inc.
    100 Corporate Drive
    Mahwah, N.J. 07430-2041
    General Office hours:
    8:30 AM to 5:30 PM ET, M-F
    Tel. 201-762-6500
    Fax. 201-762-6670
    Parts Support hours:
    9:00 AM to 5:00 PM ET, M-F
    Tel: 201-762-6392
    Tech & Operational Support hours:
    Tel. 201-762-6666
    Fax. 201-762-6687 Parts
  • Posted on Feb 12, 2009
      Sergeant:
    • 250 Answers
    The centre board may be receiving too high voltage power supply .it can be due to the fluctuations that come in power supply at many a times.just check the board for the burnt out capacitors.test all the junctions with a volmeter and replace the burnt out or faulty parts.its a common problem and will get solved easily at a minor cost.nothing much to worry about.
    • 4,806 Answers
    Hi there
    Have a look for any burned out capacitors or resistors as this sounds like its more to do with the center board receiving too much power.
    Good luck and thanks for using Fixya!!
    • 1 more comment
    • Lee Hodgson
      Lee Hodgson Feb 12, 2009
      like i said faulty capacitors, resistors bad circuitry and of course semiconductors and power controllers themselves, any one of these could be causing too much power or even feed back
    • Lee Hodgson
      welcomejee is right, i suggest you get a volt meter and do some testing, check the continuity between points, ckeck the capacitors and resisters for the correct voltage, the capacitors will say the voltage on them so a good magnifying glass would be an advantage so can read the components
    • Lee Hodgson
      leave this post open until you get home, then log back on here, we will be able to help you much further if you could work on it at the same time. What we need you to do is test the components.
    • 10,594 Answers
    Problem would be over voltage supply to center channel board. Please check supplied voltage to center channel board and that should be accurate as per written in manual / PCB connector.
    • 1 more comment
    • Shahid Electronics
      Shahid Electronics Feb 12, 2009
      I told you cause of problem. To check voltage you need Digital
      Volt Meter.
      if you want to do it yourself then have service manual of amp, soldering iron, volt meter etc.
      You should have experience of electronics repair and basic electronics knowledge.
      Shahid Electronics Feb 17, 2009
      Do you have related schematics or service manual?
      If yes, please email me welcomejee@yahoo.com to help you as I don't have it.
    I have a marantz sr 7001 amp and am running canton 4ohm speakers to front and centre should my amp get really hot and go into protect mode when I am giving it some serious volume
    it is not made to drive 4 ohm loads.also if you measure the impedance on the speaker,at some frequencies,it is closer to 3 ohms.This will cause the amplifier to shut down.Today's amplifiers are embellished specs.the old marantz 2325 was 125 watts a channel and weighed 80 pounds.It would eat alive some of the 1000 watt home theater amps of today.Marantz is very nice stuff.
    Jan 03, 2011 | Marantz SR-6300 Receiver
    My Marantz sr 4001 receiver has no output. Is
    There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
    Jul 18, 2010 | Marantz SR4001
    Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
    There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
    Aug 17, 2009 | Marantz SR-18EX Receiver
    Audio glitch on Marantz SR-19
    It's probably not heat due to the Marantz' large frame and heat-synchs.
    This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
    If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
    I hope this helps.
    May 31, 2009 | Marantz SR-19 Receiver
    Marantz sr 4200
    This is an indication of some bad solder connections on one of the boards. It could be the power supply board, amp board, or the digital board. I would like to be more specific, but this is not a common problem with those symptoms. Bad solder connection are a common problem and can cause many different unusual symptoms. Unless you have excellent soldering skills, it would be best to let a service center repair this for you. This is a very good receiver and is well worth getting fixed. If you have excellent soldering skills and are willing to take a chance on fixing it yourself you could save yourself some money, but be aware that if you make even one mistake while soldering, you could easily cause much more damage than you started with. Some of the components that may need to be resoldered are surface mounted IC's that are very difficult to resolder and if you have never done this before it is not a good idea to start learning how to solder on such a nice receiver.
    Let me know if you need any further help.
    Dave
    Oct 27, 2008 | Marantz SR-7200 Receiver
    Marantz SR18-no sound
    I have worked exclusivly on marantz recievers, for the last seven years, the loud 'pop' you heard, and smoke, was 90% that one of the amplifier channels, on the amp block, has blown, and consiquently the unit stays in protect mode. It will power up, and decode audio, and even show an f.m. stereo on the tuner, but you won't get the 'happy click' of the protection relays, until the channel is repaired. also replace the 5fd memory capacitor on the front micro board behind the front panel. If you have someone repair the channel, make sure that the tech resolders all of the connections on the molex connectors on the amp block. there are 10 of them, five male and five female, The bad solder on these are what caused the problem in the first place.
    Nov 29, 2007 | Marantz SR-18EX Receiver
    Loss of volume on left channel
    Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
    The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
    I'm amateur radio and engineer
    Oct 15, 2007 | Marantz SR-5200 Receiver
    SR4300 Centre Channel
    Hi...
    Try another GOOD speaker on your centre channel.
    If the buzz ....buzzes off, it's a bad speaker.
    If not , It's in the power amp section on the unit.
    Sep 14, 2007 | Marantz SR-4300 Receiver
    Marantz SR 7200
    It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
    I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
    Good luck.
    Jan 29, 2007 | Marantz SR-7200 Receiver
    135 people viewed this question
     Grubhead
    Grubhead
