Question about GE Spacemaker JMP28 Electric Kitchen Range
GE Spacemaker JMP28 Electric Kitchen Range F1 error message
I have a GE Spacemaker JMP28 Electric Kitchen Range that displays -F1- error message. I cannot clear this. The burners work but I cannot turn on the oven because of the error message. Please Help!!!
  • Anonymous Feb 16, 2009
    mine displays f-3 error.usually when the burner and stove are on at the same time.
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
(*UJ
Posted on Oct 01, 2010
Makes beeping noise and F1 appears in window
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 27, 2010 | GE Spacemaker JMP28 Electric Kitchen Range
What year was the GE JMS08BW2WH manufactured?
Your oven was manufactured in the year 1995.
Good Luck Please rate 4 thumbs for the free answer
Here is manual on link below.
http://genet.geappliances.com/DocSearch/pdf/49-85931.PDF
Mar 14, 2010 | GE Spacemaker JMP28 Electric Kitchen Range
F-3 error code for ge spacemaker electric oven
The oven temperature sensor is bad.
Open the oven,look in the bach wall of the oven up high. It is thin metal about 3 inches long.
Unplug the range before you attempt replacement.
Feb 25, 2010 | GE Spacemaker JMP28 Electric Kitchen Range
Older ge spacemaker range, temps wont boil water on stovetop, oven takes hours to hit 300 degrees could it be wiring or thermostat? says pn PLT135-3 owners manual [dont have] PLT059-2 model number...
Check your breakers to the oven. It sounds like one of the two of them have tripped and you are only getting 120 VAC.
Do you have a volt-ohm meter, and know how to use it?
Dec 18, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
My jmp28 range has lights and burners working, we put the range into self cleaning and left it, now the oven display is not lit, it is finished and the door is locked. Tried reseting power, did not help.
The thermal fuse for the controller board has failed. Needs to be replaced.
You can use a screwdriver to unlatch the door by reaching inside the top. You will need a flashlight to see what to push on to disengage.
Dec 01, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
NO power to large coil
Your stuff works on 220 volts, all this is, is two 110 volt circuits going to the same location. The large plug that is plugged up from the stove more than not there is one of the prongs that is burnt out
Aug 09, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
Broil element replacement
Yes. Most all ovens built today are made so you can replace the elements.
Dec 22, 2008 | GE Spacemaker JMP28 Electric Kitchen Range
Ge broil element replacement
you can do it your self, just TURN OFF POWER FIRST!!!!!< wires to elemnt are ALWAYS LIVE!!!!!, screws remove it form the rear of unit, pull gnetly and there eshould be enought wire to pull out, if not , youll need to remove hte unit forom install to get behind to acess the wiring
GE oven
try turning off the power to your oven and turning it back on. if that doesnt work then you are going to need a new control board.
Feb 08, 2007 | GE Spacemaker JMP28 Electric Kitchen Range
GE Spacemaker JMP28 Electric Kitchen Range Logo
478 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
