Check that you have replaced the vacuum line for the distributor to the base of the carby block. Turn the 2 idle mixture screws all the way in till they touck the bottom. Then turn both out about 2 full turns . Get the engine running and hold at fast idle and adjust screws until a steady idle is achieved . Allow to idle and screw each screw in or out slightly until even idle is achieved. You will hear the engine revs increase or decrease when you have gone too far so adjust to about the middle of turns
SOURCE: '86 nissan trk inconsistent idle(hi,lo,lopes)z24 carbed
internal vacuum leak in carb. replace with weber carb you will be very happy
