Question about HP Compaq nx6110 Notebook
Usb flash disk not detected
My compaq nx6110 wont recognize a usb flash disk on any of the four ports. someone wanna help?
There can be several reasons for Flash Drives not being detected by your computer.
First your computer is not able to provide drivers for your Flash Drive. Now, for your information, you do not need to install any drivers from outside if you are using Windows 2000 SP4,Windows XP or Windows Vista as they come with native support for these devices.
If you are thinking that you are already using one of these versions of windows still your computer is not able to mount your Flash Drive. Don't worry,that's why I am writing this article. Just read on...
If your are not on one of these Windows version then your problem can be easily resolved by just installing the drivers which you get on a disc that comes with your Flash Drive. If you did not receive any disc,try checking out the manufacturer's website and it should be there for sure. If still no luck,then try contacting me....
Remember, everything is explained here assuming that you are on Windows XP but need not worry as other Windows like Vista should work the same way.
Let's come back to the topic..
There are several possible reasons for Flash Drives not mounting on your computer. Mentioned below are few of them:
Drive Letter Conflict
Flash Drive not formatted properly
Windows require some patch or update
Problem with the USB port
Physical connection problem
So, let's start with the first one, that is, drive letter conflict.
Now, this can be the problem when you are trying to use your Flash Drive in a network environment. The best possible solution to this problem is to change the drive letter assigned to Flash Drive. This can be done by going to Disk Management and right clicking on Removable Drive and then clicking on Change Drive Letter. You can select any drive letter which is not assigned by windows to any drive or partition in any computer inside a network. Also, before changing the drive letter it's recommended to check if your Flash Drive is showing in Device Manager under Disk Drives. If it's not there that problem can be something else.
If changing Drive Letters does not help and drive is showing in Device Manager then probably you should try disconnecting that computer from the network by taking out the network cable or if you are inside a corporate environment then try contacting you IT deptt to know the drive letter not being used anywhere.
Let's talk about the second scenario. If the drive is not formatted properly that means that it's mounting up and being detected by the computer as well. It's just would be giving a message to Format the Drive when trying to access it. This can happen if the File System has corrupted on Flash Drive or its not formatted in the supported format. For example, if you are trying to use a Flash Drive formatted in Ext2 file system in Windows Computer. The only solution to this problem is to format the drive in the supported format. For windows you should always format the drive in Fat or Fat32 and in Macintosh you should use MSDOS as this will also be supported by Windows computer. Please note formatting the Drive will ERASE all data. So, if you have any important data kindly try using a different computer to see if drive works or contact a Data Recovery company. If you want some reference kindly leave a comment.
Also, if you are not able to format the Flash Drive, please try using the HP USB Disk Storage Format Tool. It's made by HP but works on generally all Flash Drives.
Now let's talk about problems that can happen because of any updates or patches. No matter if you have the latest service pack for your Vista or XP computer. Still, there are few updates or rather say patches which need to be installed if you face any such problem.
Vista Patch
Please find the link to Vista Patch at the end of this article.
As per Microsoft the patch will fix the following issues:
" When the computer resumes from a suspend state or from a hibernation state, the computer stops responding. Additionally, you receive a "0x9F" stop message on a blue screen.
" The computer takes a long time to resume from a suspend state or from a hibernation state.
" The computer takes a long time to resume from a suspend state or from a hibernation state when you use a VIA controller.
" The computer stops responding when you use an Authentic USB fingerprint reader. Additionally, you receive a "0xFE" Stop error on a blue screen or a "0x9F" Stop error on a blue screen.
" The computer stops responding when you use a USB Bluetooth audio device.
" The computer takes a long time to resume from a suspend state or from a hibernation state when you use an Enhanced Host Controller Interface (EHCI) controller.
" The computer stops responding when you remove a USB device. Additionally, you receive a "0xFE" Stop error on a blue screen.
" When a computer resumes from a suspend state or from a hibernation state multiple times, you receive a "0xFE" Stop error on a blue screen.
So go and install this even if you are facing a different problem related to but not similar to this.
Another patch for XP Service Pack 1 is also include at the bottom.
There are chances of problems with USB ports as well which happens rarely but the possibility is still there. The best way to identify is to attach any other USB device on the same port and check if that device works or not. For Example, USB Printer. Also of you are using a Desktop and inserting the drive in some front USB port then try using some port at the back.
Here , I would like to add one more point. If you have a high capacity drive like 8 GB and you are trying to use it on an old computer then due to inadequate power support the drive may not mount properly.
Sometimes, even if the icon for Removable disc appears under My Computer,the drive may not work properly as the complete capacity will not be mounted in case of inadequate power. You can check this by right clicking on Removable Disc and then clicking on Properties. If one this window, both free and used space is showing 0 KB then this can be the possible problem. In order to fix any issues related to inadequate power supply you can purchase USB Power Hub from any computer store and attach it to the USB port. What it does is that it will convert the low power supplied by USB port to little high power.
But, remember this problem generally happens in case of old computers. Before purchasing USB power hub, you can also try the back port of your computer if you are on Desktop.
And Last but not the Least, improper physical connection is the general cause for Drives not getting detected. This may happen if USB port or connector on Flash Drive has bent or physically damaged due to which drive is not able to make a contact with pins on USB port. In this case, you should also look the inside area of port or connector and if any damage found please take it to some local technician of Drive manufacturer to get it fix.
So, this was my first article. Any feedback will be appreciated.
Thanks
Article Source: http://EzineArticles.com/1526594
Posted on Jun 22, 2011
    President:
  • 2,692 Answers
Is the flash dish recognized by any other computer? If so , then the problem is with the ports. Maybe they are not turned on in the BIOS setup screen? If not then the flash disk is no longer operational.
Posted on Feb 12, 2009
  • Thomas F. Schneider Feb 13, 2009
    I sure would like to know why you though my answer inappropate; Especially compaired to all of the the other  answers you have received. May you just don't like the answer?
Work around for USB Device Software for Compaq nx6110, Windows xp SP 3. my laptop some times refuse to detect and read the USB devices like : flash disk, external hard disk, modem,... it use to write that...
first off why run XP the Virus magnet?,Microsoft and hp dropped
support on this 3 years ago,,
not only that XP does not support most USB devices.
sure some old devices, but not new ones. (unless maker says otherwise and offers software to run on XP)
you are direct connected. to USB to external HDD.
That external disk, my guess has no external supply right?
that means it will overload many Latptops
the power spec, on USB varies, by different ports used and maker of the laptop...
I solve that horror by only buying external HDD what have wall power pack connected, mine is 12vdc 2amps, and will work on any PC made , ANY !
it uses its own power, so never overloads that weak PCs USB port.
here is the USB spec from WIKI page "USB" 0.5amps is gutless.
  • 0.5 A (USB 2.0)<<<<<<<<<<<<<<<<<
  • 0.9 A (USB 3.0)
  • 5 A (BC 1.2)
  • 3 A (type-C)
  • Up to 5 A (PD)
0.5 amps that is, 500mA, about 1/2 what hdd needs. to be happy.
yours is the first one, the weakest they made.
that is not enough current to spin up any HDD, from dead start.
cures: (all)
  1. get an external SSD drive,
  2. use and external case on external drive with its own powerpack
  3. buy and an EXTERNAL USB powered hub that is USB3 rated and it might run your drive connected to it.
  4. get newer laptop, one with USB 3 and runs w7 or newer.
Jun 27, 2017 | HP Computers & Internet
My ASUS F5SL laptop doesn't recognize my flash drive. It recognizes my mouse, my mp3 player but won't recognize my flash drive pen or my psp. Can, please, someone help me? I'm running Wind
have you tried different usb ports? hit the windows key and the R key at the same time and type diskmgmt.msc and go into disk manager and see if the flash drive shows up in the list of disks installed.
Jun 23, 2012 | ASUS Computers & Internet
Hp notebook Nx6110 having following problems (1) When it is powered on sometimes it fails to start and gives msg NON SYSTEM DISK OR DISK ERROR ...PRESS ANY KEY TO CONTINUE (2) its bluetooth device...
I will first try to restore the system first to the point when you had no such problems.
Then, run anti virus program like kaspersky. (Some programs catche virus or spyware well but don't fix well.)
If your problem stays same, there are two possible problems. (hightly possible first)
1) Motherboard Problem. (If your notebook were shut down due to any electric shock like sudden power down)
2) Power Problem. (Short power) - example bad battery
I hope it helps.
May 26, 2011 | HP Compaq nx6110 PC Laptop
Hp compaq nx6110 laptop usb power surg and usb not recognize problem please give me a solution in above mentioned problem
try other usb if same problem with other than go to device manager (controlPanel> System>Hardware> Device Manger) and delet all USB Contorollers from Universal Serial Bus Contorollers and restart your computer.
Mar 31, 2011 | HP Compaq nx6110 PC Laptop
My Hp Compaq Presario V3000 does not detect USB flash discs
depending upon the operating system I would go to the device manager check the usb root hub and if there is more than one remove all hubs and let the system re-install it.
Jan 15, 2011 | HP Compaq nx6110 Notebook
Micro sd 2gb card, not read.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Usb PORTS
try using diffrent ports for it or download a driver for it by google searching
hope this helps :-)
Aug 22, 2008 | Electronics - Others
HP Compaq nx6110 Notebook Logo
1,052 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
