Question about Maytag MDG7600AW Gas Dryer
Tumbling bar is loose and getting looser
Tumbling bar is loose on maytag mdg7600, how do i tighten?
    President:
  • Maytag Master
  • 2,651 Answers
Youll need to lift the top of the unit, and and form there youll gain acees to the outside of the drum assembly, the "tumbler bars" are secured by 5/16 screws from the outside ofthe drum assy
Posted on Feb 13, 2009
MED9700SQ dryer sensor light comes on but will not run
I have the same problem with the same model Maytag dryer. I called a repairman and paid a hefty service charge and the repairman found that the electronic control board needed to be replaced. This particular part (Part #8558455) costs between $250 and $350. Evidently there are many people with the same problem.
Feb 02, 2013 | Maytag MED9700S Electric Dryer
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 13, 2010 | Maytag Dryers
My tumbling bar in my dryer in coming loose - how do I fix it
Remove the 2 screws holding the dryer door hinges and remove the 2 screws on the opposite side of the hinged ( in the door opening ) . Then the front panel will pull out ( from the top ) and off . This will give enough room to use a driver to tighten the baffle screws .
May 23, 2010 | Maytag MDG7600AW Gas Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
It is heating up but not tumbling correctly
Drive belt for the drum is probably broken and needs to be replaced.
May 27, 2009 | Dryers
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryer Not Tumbling
If you are talking about the front of the machine, above the SERVICE ACCESS PANEL, then after you remove the screws at the bottom of the FRONT PANEL, pull the panel toward the front and the top of it will pop out. It is in place with small GUIDE SCREWS and a couple of removeable clips.
If your barrel is not tumbling you probably have a broken BELT and it needs to be replaced. Easier to do this from the back I think. It goes all the way around the barrel of the dryer, so you have to put it on the barrel then attach to the IDLER PULLEY and SERVICE BOLT.
Jan 05, 2009 | Maytag SDE3606A Electric Dryer
Maytag elc dryer
Your drive belt is old and has glazed. It will likely break soon. Replace it. Make sure the belt contact area is clean and free of any kind of dirt or grease.
Dec 05, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
147 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
