Question about Konica Minolta magicolor 2430 DL Laser Printer
My printer won't print transparencies (for use in teaching) even
Though I bought the ones for laser printers.
  • bobthia Mar 06, 2009
    I cannot print transparencies either. I bought 3M Multipurpose film. We checked to make sure we used the glossy side to print, but the transparency comes out blank. We also tested on plain paper to make sure the info was set up correctly.
  • 10,865 Answers
Check that you are putting the transparency right side up in the printer. That may solve the problem.
Posted on Feb 12, 2009
My dell 3100cn won't print, even though it says the printer is ready
look inside of printer.see if something is pulled or unpluged. see if there is ink and paper inside.
Jun 20, 2013 | Dell 3100cn Laser Printer
Can you print transparencies on a officejet j4580 all in one printer?
Yes, provided the transparencies you are using is heat resistance for laser printers.
If not heat resistance the film will melt onto the fuser drum, and this will damage your printer.
Dec 11, 2010 | HP OfficeJet J4580 All-In-One Laser...
I have a lasser printer CANON LBP-5200 can I to print on photografic paper?, how many gr.?
Are you saying photographic paper or do you mean photoprint paper?
Yes, laser printer print just fine on photoprint paper. I use 20 lb or 22 lb bond. 18lb is a little light and is not usually photoprint.
If you mean overhead transparency, you have to try it. On some units the overhead transparency will melt a bit and wrinkle. You may need to try different makes of transparency. Make sure it says OK for laser printers!
Apr 17, 2010 | Office Equipment & Supplies
I want to buy a printer that I can use only transparent paper
You can get transparency foils for either laser or most ink jet printers.
You USUALLY need to make a setting in the printer setup screen for transparency.
Transparencies take more time to dry for the ink jets so do them and don't stack them till dry. Also you have to pay attention to which surface to have the printing on. One side will take the ink, the other it won't dry.
Nov 10, 2009 | Canon Office Equipment & Supplies
How to make a transparency. Can I use the transparency for a lazer printer?
Yes you can use transparency on a laser printer.Just prepare your data that you want to print on transparency. Put transparency in your laser printer and give the print command.
Aug 31, 2009 | Office Equipment & Supplies
Print on transparencies
You should be able to. The only time you need to be concerend with that brand is when you are pringing with a laser printer. You need to have ones that will not melt in a laser printer fuser. There is no heating unit in a inkjet printer.
Apr 23, 2009 | Xerox Phaser 8200 Laser Printer
Hi, I would like to print on Transparency paper, but it will not allow me, what am I doing incorrect please . does it go into the photo tray or paper Tray ? Regards Ellen
Hi
First of all, are you working with a laser printer or inkjet? if it is laser make sure that you have the correct transparency, IT MUST BE HEAT RESISTANT! if it is not,u'll end up buying a new fuser unit. then...
1. Put the transparency in your MP tray
2. When selecting "print" click on properties and select your MP tray as your source,
3. Select Transparency for you media type.
after doing this you will be able to print your transparencies.
I hope it helps
Kind regards
Yolande
Mar 04, 2009 | HP Photosmart C7180 All-In-One InkJet...
Printer
Firstly, BE SURE TO USE LASER PRINTER TRANSPARANCIES. The cheaper inkjet kind will melt in the fuser.
Then, in all 3: driver, software program and on the printer itself using the front panel, change the paper type to transparency.
Good luck.
Jul 15, 2008 | Dell 3010cn Laser Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
USING OHP TRANSPARENCIES
You can't use ordinary transparencies if you use ink... find a special transparency that is sold by Espon, but that's rare to find now... only Laser printers can print color or black on ordinary transparency
Oct 18, 2007 | Epson Stylus C64 InkJet Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
90 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
