Question about IBM Wheelwriter 30 Typewriter
IBM Selectric - keys will not come back up
I was just given an IBM Selectric that has not
been used in 15 years. It looks like new and
the letter prints, but the key will not come back
up. There are a couple of keys that will come back
up.
Thanks for any advice.
  • marymistrett Feb 17, 2009
    thanks - I guess I'll have to find out who does this
    and how much it would cost.
  • IBM Master
  • 3,594 Answers
This is not an easy repair, the keylevers and trip pawls get gummy over the years it needs a chemical cleaning an lubrication.
DickyO
Posted on Feb 12, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
IBM correcting selectric won't type
Michele, this machine perhaps sitting unused for few years. SO, It needs a thorough cleaning - I mean Clean it before you power up. What about the ribbon condition. Good luck and happy back to yester years.
Apr 08, 2014 | IBM Office Equipment & Supplies
IBM Selectric II jammed
The lubricants dryp over the years. Try spraying everything with WD40 you can't hurt it.
DickyO
Feb 23, 2013 | IBM Correcting Selectric II
My IBM Selectric II will occasionally not print letters or parts of letters. Why does it do this?
Your Selectric II (a wonderful machine) is in need of cleaning and adjustment. When I did this, I got $65.00 for the service ... that was years ago. I don't know anyone who does this work any longer though a search on Google may get you results for a shop in your area. There may be a FixYa.com advertiser who can help you. Look at the ads around this answer (that is what pays the bills, after all).
Thanks for your question @ FixYa.com
Mar 25, 2011 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
My IBM Selectric clutch is vibrating and I can't type
The clutch is dry there is a hole for greasing it but you need a special grease gun you can try to get some oil into it.
DickyO
Jan 30, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric clutch on motor is vibrating
either the shift spring needs grease or the cycle clutch under the left protection shield you will see a gear with a belt to the left of that gear is the cycle clutch which has a hole to install grease
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
158 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
