Question about Toshiba Satellite A135 Notebook
Laptop wont tuurn on
  • 1 more comment
  • dylandog1967 Feb 17, 2009
    is it worth fixing??
  • ts49191 Mar 08, 2009
    power light turns purple and laptop freezes off
  • diddydaveh
    diddydaveh May 11, 2010
    have you checked the voltage coming from the power supply is correct?
  • 154 Answers
If it's a fuse then it will cost mainly for the labout - appx £95, if it's the motherboard then the sky's the limit unless you can get hold of a replacement second hand board (can be tricky)
Posted on Feb 18, 2009
  • 27 Answers
You may have blowin a fuse or the motherboard could be bad.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
Toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Feb 12, 2010 | Toshiba Satellite A40-S270 Notebook
My Toshiba Satellite M50 laptop wont turn on.. the battery has lost it's charge, and the AC adapter no longer seems to provide any juice. Is this likely a problem with the adapter, or the laptop itself?...
I've repaired a few laptops with the same problem, check out this page on power jack repair.
Did it run out of power when you were using it, or did you go to use it one day and it wouldn't turn on? because I've know people spill stuff on the friends/family laptop and not tell them about it.
Jul 30, 2009 | Toshiba Satellite M50 Notebook
HP L2000 Sudden shutdown wont power up power supply good
what makes you think the ac park is ok
19vdc measured with a voltmeter proves this , only.
a 2005 (as old as) Laptop
its not new, things this old do fail.
Laptops are like dog years.. 7:1. so yours is 84years old
to fix a desktop is super easy
to test a laptop takes greater skills, the take down. is tricky
we take out the battery,
the the pack just make the fan run in the PC
does it>? if not the pack is bad.
or the MOBO regs are shut down. (shorts on any thing inside
some times the 19vdc is ok, at that pack
then 1 inches inside the PC its dead due to that silly power jack loves to fail. but not taking the thing down and testing that
its all just a guessing game...
the only insight there is on electronics, is power first.
no power, no joy.
test the power feeds first.
Jul 17, 2017 | HP Special Edition L2000 LiveStrong Mobile...
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Battery not charging...
My impression is that you might have a defective cord if you still have your old adapter and has the same power specification try this first.
If the battery is hot and does not charge you might have a defective battery . Better have it checked at the service center before buying a brand new battery
Jun 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
No)Try the BIOS upgrade.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A135 Notebook Logo
173 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
