1. unplug dryer 2. popoff the top off 3. take front off (unscrew) now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt 4. place belt around drum and pulley make sure you add tenstion 5. replace front and top
Thank you for useing Fixya
Was this helpful?
Yes
No
Popular Solutions for Bosch Axxis WTA 4107 Electric
Trying to replace belt on Performa Model PYE22000AYW. Spring on idler is attached to idler arm, but...
(More)
Trying to replace belt on Performa Model PYE22000AYW. Spring on idler is attached to idler arm, but other end is not attached to anything, where does it go?
I have a Braun AXXIS Dryer that I just got that is leaking water onto the floor. It does not have an...
(More)
I have a Braun AXXIS Dryer that I just got that is leaking water onto the floor. It does not have an exaust hose like my last dryer.
My dryer appears to be working fine but ther is no heat - Bosch are quoting £139 call out and...
(More)
My dryer appears to be working fine but ther is no heat - Bosch are quoting £139 call out and parts charge. Is this fixable and is £139 reasonable
My machine has stopped working. If you select a programme, the 'Drying' LED (the bottom one) starts...
(More)
My machine has stopped working. If you select a programme, the 'Drying' LED (the bottom one) starts to flash. Pushing the Start button produces nothing. Any advice would be very much appreciated.
can you please send me a wiring diagram for a WTA 2000 electric dryer via e-mail to...
(More)
can you please send me a wiring diagram for a WTA 2000 electric dryer via e-mail to johan.vanloggenberg@harmony.co.za Thanks
