Question about Bang and Olufsen Audio Players & Recorders
Where can I buy an optical reader for my cd player?
When I push Play button on my B&O Beogram 5500 CD player, the cd turns and then it stops...
I was told that it may be the optical reader is gone bad.
I can not find any one who sells parts for B&O equipment.
Any idea weather the problem is the optical reader or not?
If it is... Any ideas where I can get this part?
Thanks
  • 122 Answers
Cd mech no longer available.try cleaning laser lens.try replacing 30tr6108 and30c2103 bc338 and33/16v
Posted on Jan 22, 2010
Why doesn't CD player read discs?
If it's the CR-Rom of a computer, please restart your computer.
If the failure persist, means that the optical reader of your CD player is fauling.
No sure it should help but clean your optical reased.
Hardware 101 Cleaning The Lens Of Optical Disc Drive
Actually the same goes for a standalon player.
With costs as low as they are currentl, you sinply should remove the CD player of your computer and intall a new one
If this is not the answer you expect is because your question was not well specified.
Oct 26, 2015 | Audio Players & Recorders
When I push the select button to DVD I get Err and the red VCR light stays on. The screen displays INCORRECT DISC. What can I do?
Did you try with other disk?
If you get same error for any disk, the optical reader is defective.
You might use an optical cleaner
Cleaning CD DVD or Blu ray or Other Optical Drive
How To Clean Slim DVD Drive Lens and Laser From Dust
How to Clean CD DVD Laser Lens in Computer
Memorex CD and DVD Lens Cleaning Kit
If you don't get any result afterr the cleaning, you've got an electronic issue and should decide if you repair it or buy a new one.
Aug 15, 2015 | Televison & Video
Our church has a Phillips 760 cd recorder. We bought it slightly used ( or so we were told) and at first it was ok... Finicky with usable CDs, but ok. But now after a few months of use, it will start to...
try buying optical clean for the cd play run it few time before you do any thing else, make sure you buy one that has media disc cleaning fluid. put few drop of liquid on each pad push play, fast forward, stop reverse forward, stop few times, let it run until it stops. you mite find it at walmart but you may have to go dvd or record store, radio shack may also have it
thank you rod
Feb 28, 2015 | Audio Players & Recorders
My beogram cd 50 is not working - it will not read the disc and the door just opens. Is there another cd player that can connect to the beogram 5500 system?
YES THE BEOGRAM CD5500/6500/7000. ALSO ANY CD WILL WORK THROUGH THE CD CONNECTION JUST USE A 2 PHONO TO 5 PIN DIN PLUG ADAPTOR,NO R/C OPERATION IS POSSIBLE UNLESS YOU USE A B&O PRODUCT.
Jan 15, 2010 | Audio Players & Recorders
My pioneer cdj 800 simply wont work!!
Your traverse assembly is damaged, and will need to be replaced. Although self-repair is not recommended, you can buy the part and bring it with you to a service center for replacement.
Pioneer CDJ800 Part - CD Reader for CDJ800MK1
Pioneer CDJ800MK2 Part - CD Reader for CDJ800MK2
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 02, 2009 | Pioneer CDJ-800 Turntable
Aiwa CSD TD310- manufactured 2001 - looks like this(above)1)Problem getting cd to work; 2)need help with "sleep" button:how to set
Well, for the CSD-ED27 the sleep works like this:
1. press STOP/MEMORY and then also
2. press PREPEAT/FM MODE/OSC
3. your display will show 10
4. use the tuner - & + to good from OFF-90 mins
As to you CD player not playing:
it is sounds like the spinner might be not spin completely flat to the optical reader. This happen with my portable CD player, however at this time I do not have a fix for you. Good luck though.
Mar 20, 2008 | Aiwa CSD-ED27 Boombox
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
CD player won't play random
the most likely problem is a weak or failing optical pickup. try a cleaning disc first there may be dust on the lens. do not use any liquid to clean the lens. remember this is an optical system if it can't focus properly or "see well" it can't read.
Feb 03, 2008 | Audio Players & Recorders
355 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
