When TV is first turned on it clicks on and off several times .
We have a Samsung LCD TV purchased in Dec. of 2007. Mo #LNT4061F. When we turn on the TV it turns on and off many times before we finally get a picture. We are allso getting green lines and pink dots on the screen.I am concerned because when I go to web sights I find that my problem is not unique to me. If you cannot help me could please tell me who I can contact in regards to the TV.Thank You,Jeffrey L. Lunder
  • 1 more comment
  • scsmith Apr 04, 2009
    I have same problem except now the tv does not even turn on. Please advise! Can most tv repair firms fix this issue?
  • Barja Apr 12, 2009
    Tv used to get on after couple of click sounds, but now I only hear clicks but it does not turn ON,
  • johnpez123 May 05, 2009
    where can i buy that board
The set has bad capacitors on the power supply board. The tops of the capacitors will be domed/swollen. Replacing the capacitors will fix the problem.
Posted on Jul 24, 2009
  • 98 Answers
Need to replace the main board.
Posted on Feb 12, 2009
My samsung tv model LNT4061F keeps turning on and off continuely and when it does come on it has a lot of different color lines in it with no picture. To describe it better it looks like wall paper. I...
In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Dec 12, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Tip
SAMSUNG LNT4061F - LNT4661F SERVICE MODE
General Alignment Instruction
1. Usually, a color LCD-TV needs only slight touch-up adjustment upon installation. Check the basic characteristics such as height, horizontal and vertical sync.
2. Use the specified test equipment or its equivalent.
3. Correct impedance matching is essential.
4. Avoid overload. Excessive signal from a sweep generator might overload the front-end of the TV. When inserting signal markers, do not allow the marker generator to distort test result.
5. Connect the TV only to an AC power source with voltage and frequency as specified on the back cover nameplate.
6. Do not attempt to connect or disconnect any wire while the TV is turned on. Make sure that the power cord is disconnected before replacing any parts.
7. To protect against shock hazard, use an isolation transformer.
For more click on the link bellow. using the search tab on the right top corner to find you product ..
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Apr 08, 2015 | Samsung Bn44-00167a Lnt4061f Power Supply...
TV takes long time to turn on.
most likely the power supply board is starting to fail, soon it will not turn on at all.call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
LNT4061F LCD TV Picture Problems
yes it can, but i would lean more to a bad T-con or control board the board is around a hunderd dollars from Samsung on the web or Andrews Electronics on the web
Dec 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Turn on tv and purple pixels like snow are spread around tv
Write down your serial # (found on the back or on the side) and your model # and call 800-Samsung. The issue has to do with the capacitors and if your TV was manufactured between Dec 2007 and May 2008 they will send a repairman out to repair for free (one time only). I just called and they are sending someone out to repair mine. Apparently there are tons of people experience the same problem.
Sep 12, 2009 | Samsung LNT5265FX 52 in. LCD Television
When I turn on my tv it clicks several times Samsung 52" LCD HD T
It sounds like the tuning unit maybe nearing it's end and this could be costly and a new unit maybe better and more cost effective in the long run.
Save money and time and consult with known stores that sell alot of TV units.
Ask them about their prices, warranty, polices on (out of box TV units).
I speak from experience on purchasing some of these fine units which has worked out for me in the pass.
I hope this helps.
Jul 08, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Samsung model LNS4051DX/XAA won't turn on, just clicks
THE PROBLEM IS Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Nov 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LCD TV Image Retention...I Think
I have not noticed that with my set, Sony Bravia 2007 1080I.
Uh, I have a bigger problem though...
I had just paused my live tv for about 40 minutes on abaseball game and now I have green burn in.
I'm in the middle of searching the net for solutions. I have tried:
pure white screen for 30 minutes (no change)
"fuzz" for 1 hour (no change)
turn TV off for 12 hours (no change)
I'll now try to power down fully for 12 hours and see what happens.
Apr 26, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
406 people viewed this question
Top Televison & Video Experts
