Question about InFocus LP 650 Multimedia Projector
LP 650 Fan is on but it's continuously "searching"
The Projector was working fine and now it won't connect through the Computer 2 VGA slot. It works fine through the the standard AV and Component connections though. Any Idea why?
Also, what kind of connection is the computer 1 slot?
  • mxs0612 Feb 17, 2009
    Looks like the Computer 1 slot is a M1 connection. Anyone know a store I can go to that sells M1 to VGA adapters?
    thanks
  • 146 Answers
SOURCE: Loses the computer connection and just keeps searching
check connections to the computer, if USB connection, try another USB cable.
Posted on Jan 05, 2008
projdoc
  • 2237 Answers
SOURCE: LP 130 PROJECTOR SCREEN IS GREEN WHEN I HOOK UP DVD WITH COMPONE
the cable might be the problem. swap out with another cable. other than that, make sure that the correct input is selected and the resolution matches.
Posted on Aug 18, 2009
  • 167 Answers
SOURCE: infocus screenplay 4805 not communicating with PS3 console.
Try pressing the "auto image" button on the projector itself. This sometimes solves these types of problems.
Posted on Nov 29, 2009
  • 167 Answers
SOURCE: Infocus X2 searches won't display desktop
In the projector's menu under "sources" make sure that the box to the right of "Computer" is checked. Also check the box at the bottom of that page that says "auto source select" or something. But it is the last thing on that menu and should be checked.
Cheers
Posted on Dec 30, 2009
RadarRon
  • 398 Answers
SOURCE: connected VGA cable to my pc and projector.Searching only
First off be sure that you plug into the input connector. As you look at the back of the projector it the VGA connector on the left. Also make sure you activate the VGA output of you computer (This mainly applies to laptops and secondary Video jacks on PCs).
Posted on Jan 15, 2010
Where is the projector connection on vaio fit
Insert one end of the VGA cable into your Sony Vaio. This is located on the left side of your computer.
Turn off the Infocus projector before connecting the opposite end of the VGA cable into the projector. The VGA input slot is located in the back of the projector.
Turn on the projector and allow time for it warm up.
Change the video output source on your computer to display through the projector. Press the "Windows" button and then "LCD/CRT" button on your Vaio keyboard to change the display source. On a Sony Vaio, the "LCD/CRT" button is usually "F7."
5
Focus the projector to most effectively display content from your computer. You can manually focus the projector or press the "Auto focus" button on the top of the projector.
Oct 02, 2013 | Sony Computers & Internet
Tutorial
Hi Connect your computer monitor out VGA connector to Computer input VGA connector of projector. Select source in projector (with remote) as computer/RGB/VGA as terminology used on the projector..
The projector will work as large screen projection monitor for the projector.
If you want to use monitor and projector both, you can use 1IN-2 OUT VGA distribution amplifier (Commonly called as "VGA Splitter"
Jun 26, 2012 | NEC Np13lp - Projector Lamp - 180 Watt -...
Infocus lp770, trying to hook up to apple computer using the usb port? will this connection work to run the 770?
Hi!
You need to hook it up using VGA or HDMI for it to transmit information from your Apple computer to projector. You can check the Ports available at the back of your projector and you can Purchase cable needed from either Apple or Infocus or any computer store.
Hope this helps.
Sep 05, 2011 | InFocus LP 770 Multimedia Projector
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
May 21, 2011 | InFocus LP530V Video Projector 2000 ANSI...
Hey my InFocus LP530 wont detect my pc/laptop, ive changed the auto sorce select to on but still nothing, so i changed it to off and tried all sorces manually but still nothing, Any ideas?
set the pc screen resolution to a low setting.
connect the vga output on the pc to an external monitor and check that the video appears on the external monitor. change the mode of operation on the pc until it does appear.
then disconnect the external monitor at the end of the vga cable, and connect the free cable end to the projector and auto source search for the vga input signal
Apr 20, 2011 | InFocus LP 530 Multimedia Projector
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But...
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
Projector fires up, menus display, search finds the attached computer but all that displays is a blank screen, no desktop. We had a lightning storm last week that spiked a network switch and two printer...
try brand new cables. I think a spike would possibly do this, doubtful though since the projector itself is not fried. also try reflashing the unit with the newest firmware.
Jun 30, 2010 | InFocus LP 820 Multimedia Projector
Connected VGA cable to my pc and projector.Searching only
Jan 15, 2010 | HP VP6111 Multimedia Projector
Dell 2400MP out of range with vga connection
make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
Aug 18, 2009 | Dell 2400MP DLP Projector
Can't get projector and computer to connect! no image
CHECK THE VGA PORT OF THE VGA SPLITTER IT WILL BE OK IF U CONNECT A MONITER FROM THE OUTPUT END AND SEE IF THE PORT IS OK THEN LATER U CAN GO FOR CHECKING PC AND CABLES.
Apr 08, 2008 | Office Equipment & Supplies
InFocus LP 650 Multimedia Projector Logo
27 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
