Gear shifter goes in everything, but gets stuck when I try to put it in park
There is a plastic actuator stick under the shift knob. Remove the "horse shoe" clip from the shift knob and remove knob by pulling strait up. You can twist it right and left a very small amount to loosen the knob, but not much.
Once you have the shift knob removed you will see the plastic actuator stick. Push down on the stick and put shift lever in park. If that works, the shift knob or stick is worn out.
Let me know.
Regard,
when in park the gear shifter button gets stuck
