My free view box says no signal with every channel
  • 265 Answers
this could be due to your ariel, it needs to be external and digitally reconised.
look at your neighbours ariels and point in the same direction as theres
Posted on Feb 16, 2009
Hi fixya I don't have card in PCMCIA slot am told it is not important, I am only watching free view channels not subscription channels all the channels are programmed onto the TV. When TV is connected to...
You don't mention the make or model of your TV, so I am having to take a few educated guesses here: I think you need the common interface module on the TV if it's not going through another receiver. The CIM basically is the thing that allows the broadcast signal to be decoded (free or not). The SkyBox has it's own card and is already doing the descrambling first and then just sends the signal on to your TV.
I am not sure what the "free view box" is that you are using, but it sounds like it doesn't have a decoder.
May 28, 2014 | Televison & Video
Starview box keeps turning itself on and off
is your star box for viewing Virgin media and sky programs with out paying subscriptions? i know that they have sent signals to all pirate boxes to block them, to stop people from viewing free channels. the shop that sells them told me that there is no new fix for the Eurobox. hope this helps
Apr 15, 2010 | Televison & Video
How do i get my funai vcr to record from my freeview box. I can only record through my analogue channels. I have a funai vcr either 31B-750 or 31B-754 (PDC) and the freeview is an Astratc TopD2
hi, how is the free view running through the video?
Option 1(this is the most complicated way if you are using scart lead or the three color leads then skip to option 2)
if you using the normal arial socket ie arial from roof goes into free view then from free view into vid then vid into tell then what you need to do is make sure on the free view that you have a menu screen on the screen either tv guide or something that will stay on their.
Now put the video on a channel you dont use say 6 then you need to use the video remote and then enter the setup mode and then start the scanning process to look for the signal keep going until you get the menu screen that you opened on the free view then store this as channel 6 on the video.
Now when you want to record from the free view you put the video on channel 6 and put the free view on the channel you want to record.
Option 2:
If you free view box is using scart leads and has two scart lead outputs on the back, ie one for the telly and the other for the video, if you have it like this then plug telly scart into telly and video scart into video.
Now in the back of the video you should have scart lead coming from the free view, and maybe one coming from the video into the telly
If this is the case then all you need to do to record off free view is switch the video on the when you choose what channel you want to record instead of choosing 1 to 5 for normal channels you need to select av scroll down the channels past zero if you have not got av button once av is selected you should then see the free view channels try by pressing guide on the free view and put the video on av this should then let you see the free view via video if not dont worry press record for 5 min then rewind and press play it should now play back the free view you was just watching.
Option 3 now if you have it set up any other way just let me know how then i can assist you further ok.
If you have any problems following my instructions then just post me a message back and ill be glad to assist you further ok.
Many thanks for using fixya.com
Nov 18, 2009 | Electrical Supplies
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Can't view my digital channels
Get an outdoor antenna. Digital signals very rarely reach indoor antennas unless you are within ten miles of the signal origin.
May 12, 2009 | Broksonic CTGV-5463TCT TV
Star view box will only display free view channels, what do I do?
HAVE YOU SORTED YOUR BOX OUT? IF NOT LET ME NO AND ILL TALK YOU THROUGH IT
Jun 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
80 people viewed this question
 Grubhead
Grubhead
