Question about GE Ovens
I need a replacemnt Time clock unit for GE Doubleoven JKP39G0K2BG
I am trying to locate a replacement timer unit for my GE oven - I believe it is part number PS659351
Seems to be out of stock everywhere
  • 2 more comments
  • jstinton Feb 12, 2009
    the number of the GE Monogram Oven is JKP39G0k2BG with a serial number of V2606358G - according to the manual I have - we are not the original purchasers - the part number is Manufacturers part WB19X5280 - I supplied the number from
    Sorry about that - PartSelect and GE inform me the part is not available any more
    The display files - goes blank intermitently - seesm to recover when we have a power cut - looking to replace with a new unit
    Jim Stinton
  • jstinton Feb 17, 2009
    I appreciate evveryone's help - seesm I will have to go the rebuild direction - the time is working at the moment - it is intermittent - see how long it goes this time
  • Mark Egan May 11, 2010
    You can try any of these timer repair companies -
    Reply back if these help you.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Please list your full model number. (it starts with a "J") the number you list is not a part number.
  • 117 Answers
Part number is good...WB19X5280 and while it is no longer available in new, there are companies out there on the net that can actually rebuild your electronic control. Cost would be somewhere around one hundred dollars. Search the net for electronic clocks rebuilt. You will save a range and bake many more cakes once repair is made. Good Luck. If I can help further...
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
GE JKP26Gop2bg
If the oven is 23 years old, it could be time to replace it.
May 20, 2017 | GE Ovens
How does one set the clock , timer, cleaner on a GE oven that has a WB19X10006 Electronic Oven Timer
Here is a link to the GE appliance help page. I believe you will find solutions here for all your settings.
Mar 16, 2011 | GE Profile JTP56 Electric Double Oven
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Control beeps continuously. Display shows F1. Started when oven had not been used for a long time. Pushing oven and timer off buttons resulted in 10 seconds of silence before beeping resumed. Same for...
Usually, This means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 28, 2009 | GE Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Ovens Logo
279 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
