Question about Fein FMM250 Start Multimaster Oscillating Tool Kit
Information on usage of oscillating saws
When Fein's patent on oscillating saws expired, several other manufacturers started making similar products. As it happened, I happened to have job for which I thought this type of saw would be perfect, but I was not familiar with the tool, so I asked Fein about it through their website, and I called Rockwell several times over several days. Fein never answered my message and Rockwell never called me back as they kept promising to do. Finally, giving up on them, I purchased the same kind of tool from Chicago Tool, because I was at least able to get some useful information from the man I talked to there.
I still don't know as much as I would like about this tool, so I am wondering if there is any book or manual that would help me in their use. The tool hasn't yet arrived, but I would like to prepare myself before it comes.
  • Warren Jones Feb 13, 2009
    I wish that you had posted my initial inquiry when you asked if I had found a solution. I had forgotten that I had asked about a book or manual for oscillating tools, so my last posting wasn't entirely appropriate. I still need such a manual. Thanks.
    Welcome Back:
    Visited the website for 2 consecutive days.
My "solution" was that I finally realized that Fein and Rockwell do not believe in providing service, so I had to look elsewhere. I called Harbor Freight, was able to get the advice and information I needed, and purchased a oscillating saw made by Chicago Tool. I would have preferred a Rockwell Sonicrafter, but after experiencing Rockwell's attitude towards potential customers, I realized that I would not be able to get the help I needed now, nor in the future should I have bought their product.
One good thing came of this experience: I learned of your servixe, and I am bookmarking your site.I'm sure that I will be making use of it some time in the future.
Posted on Feb 13, 2009
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
FEIN FMM250 STOPPED WORKING
an broken connector wire , or powercable, an autostop activated carbonbrush? a broken field connector 1 of the 4 or an armature with a broken collector in the commutator circle. the electronic moduul to see in the last possibillity.
Sep 11, 2013 | Fein FMM250Q Select Multimaster...
FEIN FMM250 NOT WORKING
Check Cable Or Brushes. while tool is not plugged in to wall socket unscrew three 15T torque screws check cable with multimeter for open wires look at brushes pull out of holders.
Fein multi tool won't release sanding attachment
A waste of time to spend with this budget machine, unfortunately, be replaced is usually not make sense relative to the new value of the whole and in rapid succession, the following defects no spare parts to get for only a complete new head . thats fast about 50 % of the new price , NOT REPAIR is a good no the best advise in that case. if its not a FEIN supercut its not worth it to even do something to in that case it has only the name FEIN but its having very soft metals.
Oct 14, 2012 | Fein FMM250Q Select Multimaster...
Fein multimaster repair shops/centers????
Wow, I don't have a multimaster but I want one. I know they make two kinds. One that's 700.00 dollars and one that you can get at the hardware store. I'm beginning to think there might be a problem with the switches in this thing. Go to eReplacementParts.com and view the schematics to order a new switch.
Dec 19, 2011 | Fein FMM250Q Select Multimaster...
Patent activation code for nero 10.5
Your serial number has been installed too many times.
Email Nero with your proof of purchase and they will reset your serial number so it can activate the patent.
Mar 03, 2011 | Nero Multimedia Suite 10
Fein multimaster 250Q quick release not working. Spring action worked at first when lever was fully pushed (180 degrees) the tool holder would not release and the spring action was gone. How doe I fix...
either your not holding the pin in the right place or your multimaster was used with the pin in the wrong place to begin with and the lever was forced down causing the holding mech. to wear out.
Oct 21, 2010 | Fein FMM250 Start Multimaster Oscillating...
Fein multimaster sanding attachment broken
Pretty sure things like that are considered expendable. Pat yourself on the back for getting so much sanding done and buy a new one.
Sep 26, 2009 | Fein Tools & Hardware - Others
Fein Multimaster not oscillating
hi yes if you remove the gearbox from the armature housing then strip the cutter shaft from the gearbox by the circlip and bearing then the fork will fall out.
Have a look at this web www.fein.de/fein-multimaster/au/en/download/index.html
and follow link to the diagram of your machine may be helpfull.
Thanks. Sean.
Sep 22, 2008 | Tools & Hardware - Others
Fein FMM250 Start Multimaster Oscillating Tool Kit Logo
1,975 people viewed this question
Top Fein Saws Experts
Tom Chichester
ray gallant
Are you a Fein Saw Expert? Answer questions, earn points and help others
